El Taco Diablo... Mall Crawlin, now with LT for tall curbs
Discussion in '1st Gen. Builds (1995-2004)' started by El Taco Diablo, Dec 12, 2017.
  1. Nov 24, 2023 at 4:39 PM
    #1761
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Ya, I can reach the lever from the bumper. I don't have to get all the way under there or anything.
    It had to be that far back for protection, but more importantly to make the line angle better coming off the winch and through the bumper.
    essjay[QUOTED] likes this.
  2. Nov 24, 2023 at 4:42 PM
    #1762
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Changed plans for the day. Got a bit busy with other things, and also the elbows to re-route the resi hoses got here.
    I was able to do the resi mounts.
    20231124_161452.jpg 20231124_161512.jpg 20231124_163153.jpg 20231124_163203.jpg
    The list will have to be tomorrow's list.
  3. Nov 24, 2023 at 10:05 PM
    #1763
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
  4. Nov 25, 2023 at 4:54 PM
    #1764
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Got the rear brake line re-routed
    Finished all the connections at the fuel tank
    Shortened and secured lines to the trans cooler
    And cut the holes for the shock hoops
    essjay, TacoEspecial and Littles like this.
  5. Nov 26, 2023 at 10:00 AM
    #1765
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  6. Nov 26, 2023 at 3:28 PM
    #1766
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Did some cutting today.
  7. Nov 27, 2023 at 9:10 AM
    #1767
    CemenTRDgen
    CemenTRDgen Stay Flexible!
    Joshua
    Concord, CA
    2019 DCLB TRDOR Cement
    Bilstein 6112/5160, Icon RXT, BAMF Sliders, Skids, & Hybrid Front Bumper, Warfab Phantom Rear Bumper, & Hitch Skid
    Get that beast back together soon! There are snow wheeling trips coming soon!
    395979461_794244586044312_28151552871922_2dd723ca5c8d8670243165e22950a6388d0fe80a.jpg
  8. Nov 27, 2023 at 9:14 AM
    #1768
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    No way it'll be running by then. RCV axle shafts will take longer than that to get and I'm just now trying to order those today.
  9. Nov 27, 2023 at 9:30 AM
    #1769
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    How did you go about finding out where the hoops were going to poke through on the bed, before you made the cutouts?
  10. Nov 27, 2023 at 9:47 AM
    #1770
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Front to back I measured off the cab to the hoops. When measuring in the bed, I burned an inch to account for the gap between the bed and the cab.
    Side to side I found center of the frame measure, and center of between the bed measure. I used a framing square to get the distance from the heal of the wheel well to the spot on top of the wheel well.
    And I figured about 3/4 over on all of my measurements to allow room for fuck ups.
  11. Nov 27, 2023 at 11:17 AM
    #1771
    cynicalrider
    cynicalrider #NFG
    Jersey
    Def an impressive level of accuracy.
  12. Nov 27, 2023 at 11:41 AM
    #1772
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Even a blind squirrel finds a nut every once in a while :rofl:
  13. Nov 27, 2023 at 5:34 PM
    #1773
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Back on 4 wheels... for the first time in almost 2 months.
  14. Nov 29, 2023 at 8:31 AM
    #1774
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    @nDub @02hilux @ToyRyd04 and maybe @theesotericone @foxrcing07
    Question about full float axle shafts:
    These are the drive flanges I'm using https://frontrangeoffroadfab.com/diamond-axle-drive-flanges/
    I'm trying to order the axle shafts. I started by reaching out to RCV but they need to know if there is a C clip that should be on the shaft. They said since I'm using Diamond (Front Range) flanges, I should order from them because they are an RCV vendor anyway, and they would have the specifics.
    So... I emailed Front Range, because they literally will not answer the phone anymore (their site even says they don't answer the phone, to just email). Well... anyone who has dealt with Front Range will also know, they are not always very quick to respond, and they are not always all that helpful when they do respond. (Had I known this before, I probably would have ordered the drive flanges from RCV instead, lesson learned). They have not responded to my emails.
    Anyway, I am assuming (but I want to make sure) the clip on a double splined Full Float axle would only have a clip just on the inside of the flange. Which would serve the purpose of keeping the axle shaft in. I believe there is no clip on the outside of the flange, because it wouldn't be necessary and there is not enough room under the cap to allow the axle shaft to protrude out of the flange splines that far.
    Would I be correct in those assumptions? I'm trying to get the info so I can call RCV back again and get these F'n things on order.
    Other question is does anyone have any good experience with any other custom axle shaft makers? I'm seeing Dutchman Axles. Anyone know anything about them? I just need to get these things on order, because I'm thinking my luck, they will have a long lead time. And we are under 60 days to King of Hammers.
  15. Nov 29, 2023 at 8:52 AM
    #1775
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    One C-clip same position, same measurements on a RCV toy pickup birfield. At the extreme outer end of the shaft. Which makes sense since toy 30 spline aisin hubs fit that shafts which is what the drive flanges mimic just in a stronger single piece design.
    Couldn't find a picture I took, but found another's. it goes IFS Hub -> Drive Flange body -> C clip -> Dive Flange cover.
    Usually the drilled center hole is threaded for a bolt to pull the shaft close enough to get the clip on. Its a tight spec, but helps with shaft walk. Back in the day guys would do the "MARTACK" mod doing the same thing when shafts didnt have a clip.
  16. Nov 29, 2023 at 8:56 AM
    #1776
    02hilux
    Planet: EARTH
    Like what @ToyRyd04 mentioned
    C-clip between the flange and cover.
  17. Nov 29, 2023 at 9:03 AM
    #1777
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ok... let me wrap my head around this.
    The C clip goes on the outside of the drive flanges? So it's to keep the shaft from moving, farther, in to the axle housing, not keeping it from coming out? (Either way, I'm assuming the splines keep it in place to a degree as well).
  18. Nov 29, 2023 at 9:07 AM
    #1778
    02hilux
    Planet: EARTH
    Correct. Outside of the flange but covered/inside by the flange cover. The clip prevent the shaft from going in any further.
    TacoEspecial and ToyRyd04 like this.
  19. Nov 29, 2023 at 9:07 AM
    #1779
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Correct, and then to keep it from coming out further the splines taper off about 1/8" or so behind the flanges full seated. That's what keeps your inner and outer shaft play. With the tight cut of the splines and resistance from 3rd member splines and drive flange splines it takes quite an amount of effort to pull them out when servicing to get to the 3rd member out of the housing. If they slide in and out easy, splines are already wearing.
    Its nice to keep the flanges with the c-clip on for leverage when pulling the shafts.
    TacoEspecial and 02hilux like this.
  20. Nov 29, 2023 at 9:09 AM
    #1780
    02hilux
    Planet: EARTH
    Correct. I recalled rubber tapping the flange into the spine.
