El Taco Diablo... Mall Crawlin, now with LT for tall curbs
Discussion in '1st Gen. Builds (1995-2004)' started by El Taco Diablo, Dec 12, 2017.
  1. Jan 10, 2024 at 9:05 AM
    #1921
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    They would definitely be worth the time asking them.
    Their customer service was absolutely outstanding. I spoke to them multiple times and they were very willing to answer all of my questions. They also had a question come up while they were manufacturing my axles, and called me to clarify before proceeding.
    I would recommend Dutchman axles all day every day.
  2. Jan 10, 2024 at 12:51 PM
    #1922
    02hilux
    Planet: EARTH
    My advice is to check and make sure the shaft splines fit the third while it's still out.
  3. Jan 10, 2024 at 12:58 PM
    #1923
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I did
    They do
    :thumbsup:
    02hilux[QUOTED] likes this.
  4. Jan 10, 2024 at 1:26 PM
    #1924
    JTFisherman
    JTFisherman Well-Known Member
    Jake
    Texas / Missouri
    4Runner
    Had the same thought as soon as I read your first post... just talked with them and I'm sending a couple dimensioned drawings tonight after a couple changes.
    For better or worse I have plenty of broken parts and spares I can send them to reference haha
  5. Jan 10, 2024 at 2:28 PM
    #1925
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    If it's a 1st gen intermediate shaft we're talking about, I have a good one sitting on the shelf. Let me know if they need me to send it to them, and how I should address it.
    JTFisherman[QUOTED] likes this.
  6. Jan 10, 2024 at 2:47 PM
    #1926
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    If they can make them for a somewhat reasonable price, someone should setup a group buy to gauge interest and maybe bring cost down
  7. Jan 10, 2024 at 2:57 PM
    #1927
    JTFisherman
    Jake
    Texas / Missouri
    4Runner
    I can if there is interest... but what I was planning on would be far from an oem replacement. I didn't ask on the phone about a female spline end, my plan was just have them make a short male to male shaft that is between the carrier and a custom female to female end. The female to female end would be 2 stock assemblies cut down, welded and sleeved in order to avoid having to machine the blind hole internal splines.
    In my email I will inquire about if they could do the female end or not.
    The part would also have no disconnect option. I don't see the point making an add stub stronger instead of the whole thing.
  8. Jan 10, 2024 at 3:58 PM
    #1928
    betterbuckleup
    Ian
    Concord, CA
    What's the benefit of that versus just having them make a stronger OEM manual intermediate shaft?
  9. Jan 10, 2024 at 4:05 PM
    #1929
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It sounds like he thinks they're not going to be able to cut the internal splines or if they are able to it would be exorbitant cost wise because it's complicated machining. His way bypasses the need to do that as long as you have a sacrificial part. Of course welding it will be of dubious strength
  10. Jan 10, 2024 at 6:18 PM
    #1930
    JTFisherman
    Jake
    Texas / Missouri
    4Runner
    Spot on.
    Hoping strength of welds wont matter so much since they are on a much larger diameter area. OD of OEM female part is 1.815"
    I may be wrong since it has been a while since I took any statics courses, so please correct me
    .083 wall 2" as a sleeve (1.834 inner dia) - Polar MOI of .460
    Best case, the 27 spline OD is 1.1" and ill consider it solid with no spline cuts to give it the best shot - Polar MOI of .143
    if I take a best guess at a pitch diameter of the splines of 1.06 - Polar MOI of .124
    So if material is the same (4340 tube) the tube will be over 3x stronger than the shaft. where this falls apart is the tube has to be fastened to the shaft with good enough strength to outlast the shaft, but butt welding the two female ends and plug welding the hell out of the tube I think it is possible, just have to control heat so I don't destroy the heat treat, or the smart thing would be send it off for a heat treat after fabrication.
    Drawings are sent off to Dutchman so we will see what they say. If price is ok I want to test it out for the hell of it. See how much the diff can take with 37s.
  11. Jan 10, 2024 at 6:23 PM
    #1931
    Speedytech7
    I'm not great on the math aspect but when I was working as a machinist we'd get jobs like this sometimes and we always recommended a billet part rather than a weldment. It's not so much the strength of the weld, the welds usually don't break is something like this. The base material becomes brittle or loses its heat treat and cracks or shears from it instead. I've seen a lot of professional level extended CVs do this as well, always breaks at the weld but not on the weld.
    I would be interested in the finished part though. Be nice not to worry about this part of my diff breaking. I'm always really wary of binding up the 35s now
  12. Jan 10, 2024 at 10:52 PM
    #1932
    betterbuckleup
    Ian
    Concord, CA
    Ah I see the dilemma. I would also be concerned the two parts not being completely concentric to one another once welded. Not a big deal for a trailered rig, but on the road with high RPM's, seems like a recipe for not-so-fun vibrations. Unless you were somehow able to balance it after welding.
    JTFisherman and Dalandser like this.
  13. Jan 10, 2024 at 11:01 PM
    #1933
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Started adjusting the travel on the hydro bumps this evening.
    Made the spacers for the front (.5") and the rear (1"). This will give me 1.5 inch front bumps and 3 inch rear bumps. It should give me a bit more, free, up travel before I start into the bumps.
    I disassembled the rear shocks and added the spacers. They are back together. I just need to add the Nitro and Oil.
  14. Jan 12, 2024 at 3:55 PM
    #1934
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Progress is being made today :woot:
  15. Jan 12, 2024 at 5:41 PM
    #1935
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Made some more steps in the right direction today.
    Been a minute since she's not been on any jack stands.
    And a sigh of relief... the axle shafts are exactly the right fit. Never measured custom axles before. Dutchman axles really took the time to go over everything, to make sure they were right. CAN NOT recommend them enough.
    JTFisherman, essjay, nDub and 2 others like this.
  16. Jan 13, 2024 at 12:29 PM
    #1936
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Updated list
    - Install 3rd member DONE
    - Install axles DONE
    - I think I'm going to pull the 5th leaf out of the pack
    which means I have to figure out how to press the
    bracket out of the 5th leaf and put it in the 4th leaf
    DONE (we just pulled he 4th leaf)
    - Properly pack and set preload on rear hubs DONE
    - Install Emergency brake shoes DONE
    - Install rear brake calipers DONE
    - Bleed entire brake system (Will need to bleed again)
    - Figure out how to run Emergency brake line to the brakes (Ran the cables from the rear brakes up towards the front, will need to order a splitter and figure out how to finish them)
    - Make mounting plate for winch disconnect,
    and 2 unrelated breakers, at the Aux battery
    DONE
    - Wire rear winch DONE
    - Spool rear winch DONE
    - Install new Catalytic converter
    - Re-route exhaust around traction bar front mount
    - Undercoat front wheel wells DONE
    - Bleed coilovers (oil) DONE
    - Re-install coilovers DONE
    - Replace back lower control arm nuts/bolts (too long, ripping rack bellows) DONE
    - Replace rack bellows
    - At this point, pour stop leak in rack (battle for another day)
    - Would like to also re-build the tailgate/swing out/ tire carrier,
    but don't know if I'll have time.
    Also neeed to add:
    - Safety wire leaf spring bolts (drilled the heads for the safety wire and installed the bolts) DONE
    - Adjust travel on rear bumpstops DONE
    - Re-install and re-fill rear bumpstops DONE
    - Re-fill front bumpstops DONE
    essjay and TacoEspecial like this.
  17. Jan 13, 2024 at 12:37 PM
    #1937
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Now the list is:
    - Install new Cat Converter
    - Adjust traction bar, tighten, cut excess bolt
    - Cut excess bolt at leaf center pins
    - Properly torque driveline bolts
    - Fill rear diff
    - Wire rear locker and switch
    - Properly anchor RTT
    - Wire in remaining wires on tailgate
    - Install parking brake bracket, secure cables
    - Bleed brakes - all
    - Finish securing winch wires
    - Stop leak rack
    - Run new breather for rear diff
    - Re-install awning
  18. Jan 13, 2024 at 12:45 PM
    #1938
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    How's the ride height after we pulled that leaf out?
  19. Jan 13, 2024 at 12:49 PM
    #1939
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Still not sure. I have the tailgate and spare on. But I don't have all the weight in it with tools etc. If it squats the other leaf goes back in.
  20. Jan 13, 2024 at 5:00 PM
    #1940
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    More progress:
    - Cut excess bolt at leaf center pins DONE
    - Properly torque driveline bolts DONE
    - Fill rear diff DONE
    - Properly anchor RTT DONE
    - Wire in remaining wires on tailgate DONE
    - Finish securing winch wires DONE
    - Stop leak rack
    - Re-install awning
