Elbow sweat damages window trim on drivers side door
Discussion in '3rd Gen. Tacomas (2016-2023)' started by danez_yoda, Sep 15, 2024.
  1. Sep 17, 2024 at 5:22 AM
    SGJarrod
    SGJarrod Jester of the Degen...
    STL
    23 TRD OR DCLB, Blue Crush
    I got a sticker and some cool valve stem caps...
    Something like this could help the acid sweat folk. A couple different companies make them
    danez_yoda[OP] and Jaragon like this.
  2. Sep 17, 2024 at 6:13 PM
    JFyfe
    JFyfe Member
    2021 Black Tacoma TRD OR DCLB
    Was just going to recommend this to the OP. I actually bough that same product as mentioned above. Wasn't thrilled with how it held onto the door and it was a bit bulkier than I expected. Overall it was comfortable to lean on though. OP if you want mine its brand new I can throw it in the mail to you, no charge, it's just sitting on my work bench. Some one might as well get use out of it. PM me if you are interested in it.
    SGJarrod[QUOTED] and Jaragon like this.
  3. Sep 18, 2024 at 4:09 AM
    danez_yoda
    danez_yoda [OP] Member
    Yup with the DIY mod with a mouse pad or other, I need to find a way to make it stay there without damaging the soft plastic below. I'm thinking a plastic "lip" glued to the end of the mouse pad that grabs the little dip before the inside glass wiper might do the trick. Another thought is to put strong magnets inside the door and put top magnets on the mouse pad. That way it is removable when the mouse pad gets "ratty".
    If that doesnt work. Dry wall screws is next. :)
  4. Sep 18, 2024 at 5:14 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    There are also very affordable and very absorbant self adhesive disposable pads that would do the trick. Available everywhere!
    Stuck in VT likes this.
  5. Sep 18, 2024 at 5:45 AM
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    danez_yoda[OP] likes this.
