Electric Box question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wlmuncy, Jul 24, 2011.
  1. Jul 24, 2011 at 10:29 AM
    wlmuncy
    wlmuncy [OP] Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    In this picture, can someone look to see if they have a bold running through the two metal pieces. It appears designed for a bolt but cannot be sure. This is in the JC box behind the battery between the positive connection and the 120v fuse. Thanks.
  2. Jul 24, 2011 at 10:31 AM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    get me a better (clear)pic.
  3. Jul 24, 2011 at 10:39 AM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Sold the ol girl
    yours is alll wrong
    should look like this
  4. Jul 24, 2011 at 10:39 AM
    wlmuncy
    William
    Knoxville, TN
    This is about as good as I can get. It looks like a bolt goes through these two pieces as one has threads. I can't get a picture of that sorry.
  5. Jul 24, 2011 at 10:45 AM
    Superx2
    Joey
    Iowa
    be right back!
  6. Jul 24, 2011 at 10:54 AM
    Superx2
    Joey
    Iowa
    this is what is behind my battery. i also have another pic...
  7. Jul 24, 2011 at 10:56 AM
    Superx2
    Joey
    Iowa
    mine is new (truck) not quite sure what you were looking for, but this is what is behind my batt. hope it helps you.
  8. Jul 24, 2011 at 11:02 AM
    wlmuncy
    William
    Knoxville, TN
    That was what I was looking for. I by looking at the junction box details says it is this 100A AC SKT (*20)
    (for High Current). So maybe there should be a 100 AMP relay in there?
  9. Jul 24, 2011 at 11:04 AM
    Superx2
    Joey
    Iowa
    actually it does look like somthing should go in there. hold on...
  10. Jul 24, 2011 at 11:07 AM
    Superx2
    Joey
    Iowa
    the bottom one has a 140A on it.
    the top one has 100 on it.
  11. Jul 24, 2011 at 11:10 AM
    wlmuncy
    William
    Knoxville, TN
    Thanks again for the help.
  12. Jul 24, 2011 at 2:14 PM
    wlmuncy
    William
    Knoxville, TN
    Didn't fix it, but at least it looks like everyone else's JB.
  13. Jul 24, 2011 at 2:57 PM
    joes06tacoma
    Joe
    Central Coast, CA
    That's where the fuse for the AC socket/inverter in the bed goes. You don't have that option, so no problem leaving that hole empty. It does bolt in.
  14. Jul 25, 2011 at 4:45 AM
    wlmuncy
    William
    Knoxville, TN
    Anyone here ever take the JB behind the battery apart. If so can you tell me where the connection points are for the top of the JB to the bottom. Not the two bolts and one nut that hold the JB to the engine bay.
