Electric door lock malfunction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JDG67, Feb 5, 2025.
  1. Feb 5, 2025 at 4:49 PM
    JDG67
    JDG67 [OP] New Member
    James
    2017 Tacoma
    I have a 2017 Tacoma 2 door. Driver side will not lock with power button or door but will lock passenger door. Power button will unlock both doors. Already replaced door latch assy with no change. Any ideas? Also wanting to add key cylinder to base model passenger door. Is that possible?
  2. Feb 5, 2025 at 5:33 PM
    caribe makaira
    Caribbean, Puerto Rico
    Have you replaced the Driver's door Master switch?
    Phlogiston likes this.
  3. Feb 5, 2025 at 5:46 PM
    caribe makaira
    As for the passenger side key, that is part of the door latch assembly. Maybe the 2nd Gen might fit, but then you open the can of worms with compatible key(s).
    2nd Gen 2015...
  4. Feb 6, 2025 at 4:35 AM
    JDG67
    James
    2017 Tacoma
    No I haven’t replaced the switch due to the fact that it’s consistently doing everything else right except for locking the drivers door.
  5. Feb 6, 2025 at 5:16 PM
    caribe makaira
    With a small wire, strip ends and make jumper wire. Remove master switch. On connector, use jumper wire to lock. (red 2 to GND1) then Unlock. (yellow 8 to GND 1). Report back...or not.:burp:
