Electric Fan Kit???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by El TacoKing, Mar 19, 2011.
  1. Mar 19, 2011 at 12:24 AM
    El TacoKing
    El TacoKing [OP] New Member
    Eric
    Tucson
    05 Pre Runner Double Cab De-badged Black trim
    K&N intake, flowmaster exhaust, 55w HIDs, De-badged, Ininity Kappa all around w/2 1062 10" infinity subwoofers, and dvd player head unit.
    pros?
    cons?
    has anyone done it?
    Is it worth the money? ($350)
  2. Mar 19, 2011 at 5:20 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    i've read where someone did it, I'm sure a google will find it again. His install was really slick, using the existing fan shroud to get good flow through the radiator, and he put a little fan on the tranny oil cooler too.
    pro's are: no belt driven fan drag on the engine (better MPG?) or loud roaring as you idle around at low speed and after start up.
    con's: may not be reliable as OEM; poor installs don't get all the radiator included in airflow so it overheats at low speed and getting wet: when fording deep water the fan will sling water all over the engine compartment. a manual cut-off in the cab will fix that.
    found the link:
    http://www.cardomain.com/ride/832238/2005-toyota-tacoma-double-cab-pickup-4d-5-ft/page-9
  3. Mar 19, 2011 at 1:31 PM
    El TacoKing
    Eric
    Tucson
    thanks for the info!
    i think im going to do the mod! =)
