Electric Fan Turn on with Engine
Discussion in 'Technical Chat' started by tacomonazul, Aug 21, 2013.
  1. Aug 21, 2013 at 8:19 PM
    tacomonazul
    tacomonazul [OP] Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    As the title says I want my flex a lite 678 turn on when the engine is. This fan included the controls that turned it on when the radiator was 180 degrees but after some months it stopped working. Right now I have it hooked up to a switch inside the cabin that I turn on every time I turn on the truck.
    Any advice on how con I connect this so that it turns on with the engine and turn off when the engine is shut down?
  2. Aug 21, 2013 at 8:32 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
  3. Aug 21, 2013 at 8:34 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    how much power does it draw? best way IMO would be a relay that gets power when you turn the key to ACC, or run.
  4. Aug 21, 2013 at 8:34 PM
    Honey badger
    Honey badger Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Just here for the bump!
  5. Aug 21, 2013 at 8:35 PM
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    Just here for the bewbs
  6. Aug 21, 2013 at 8:36 PM
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    05 Speedway Blue PreRunner TRD Off Road
    3 inch lift OME 885, 2in AAL, 5100's, Black Badges, Fog anytime, ABS on/off, window vents, Blacked grill and rear bumper, Afe pro s dry drop in filter.
    I dont give a shit about your fan. I Wanted to see more of her. But really hope you figure out wiring up your fan.
  7. Aug 21, 2013 at 8:36 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    X2
    I love her <3
    PROOF there is a god...
  8. Aug 21, 2013 at 8:40 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    IT DRAWS 18A, HOW CAN I CONNECT THE RELAY?
  9. Aug 21, 2013 at 8:41 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    Heeeyyy calm down, she's my sister! :mad:
  10. Aug 21, 2013 at 8:42 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Weird but I like the pics that you have of yout sister. :D
  11. Aug 21, 2013 at 8:43 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    Try not to burn the cake.
    What was this thread about? ;)
    Have your relay power up with ignition on!
  12. Aug 21, 2013 at 8:43 PM
    Gabassman
    Tyler
    Georgia
    Dude thats kinda twisted to put up a picture of your sister to get attention in your thread. But I like the way you think.....wait if this is your sister why do you have a picture like this of her?
  13. Aug 21, 2013 at 8:43 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
  14. Aug 21, 2013 at 8:43 PM
    95 taco
    95 taco Battle Born
    honestly, i don't know
    My understanding of how it works is, you run a small wire ("signal" wire) to the ignition (ACC. or ON wire), and the relay gets stuck on the positive wire, everything else is is the same.
    when the "signal" wire gets power it operates the relay, determining when the device gets power.
  15. Aug 21, 2013 at 8:45 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    Back on topic... That's what I want to do but I don't know which cable to tab on
  16. Aug 21, 2013 at 8:46 PM
    Gabassman
    Tyler
    Georgia
    I dont really know how relays work but wouldnt it not not be just as easy to find a blank in the fuse box or just wire it into the acc with an inline fuse? maybe?
  17. Aug 21, 2013 at 8:47 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Fix the thermostat. You don't want the fan running full time.
  18. Aug 21, 2013 at 8:47 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    18a would be too much to pull off of the ACC circuit.
  19. Aug 21, 2013 at 8:49 PM
    HomerTaco
    HomerTaco Grill Sergeant Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    That was my first thought too...
  20. Aug 21, 2013 at 8:52 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    How can I connect the fan so that it turn on when the engine is 180 with a relay?
