Electric fan wiring and temp question
Discussion in 'Technical Chat' started by cicada83, Jan 11, 2013.
  1. Jan 11, 2013 at 6:19 PM
    cicada83
    cicada83 [OP] Well-Known Member
    Midland, MI
    Retro white SR5 4x4
    Volant ram air, Bestop soft topper
    I am converting my mechanical clutch fan to an electric unit I bought from LCE. The question I have is I tapped into my radio 12v on my fuse box when I wired my fogs. Can I use that same connection for the 12v fan connection? Or will it overload it. I am thinking it just is signaling it to turn on and not powering so it should be okay...right?
    Other question is once it is installed it says to calibrate it to turn on at a certan temp. Anyone have suggestions on how to do this and/what temp it should it start running at?
  2. Jan 12, 2013 at 3:53 AM
    cicada83
    Midland, MI
    Retro white SR5 4x4
    There is a direct battery connection but for the fan to turn on only when the car is on it requires a 12v ignition hook up. Still use the fuse box in engine compartment?
  3. Jan 12, 2013 at 12:36 PM
    cicada83
    Midland, MI
    Retro white SR5 4x4
    Yes this is the diagram. The main question is the 12v thermostatic wire. I have my 12 v tapped into from wiring aftermarket fogs on the stereo in the cab. Can I use this? Or is there a better option in the engine compartment fuse box?
    Also where is the positive wire for the ac compressor for the green wire hook up?
  4. Jan 13, 2013 at 3:31 AM
    cicada83
    Midland, MI
    Retro white SR5 4x4
    Is the compressor the pulley on the front of the engine, right top with a canaster on top of it? I have the 2.7
  5. Jan 13, 2013 at 3:34 AM
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    Good info, saving this one for later!
  6. Jan 14, 2013 at 3:26 PM
    cicada83
    Midland, MI
    Retro white SR5 4x4
    Perfect! Thanks for all the help on this!
