electric fan???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09breakfastaco, Apr 1, 2010.
  1. Apr 1, 2010 at 5:58 AM
    09breakfastaco
    09breakfastaco [OP] Member
    Richard
    Cedar Creek, Texas
    09 PreRunner SR5
    found this from another tacoma owner thinking of doing this.
  2. Apr 1, 2010 at 7:02 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Your stock fan doesn't work?
  3. Apr 1, 2010 at 7:12 AM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    frees up a little power
  4. Apr 1, 2010 at 7:15 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    ^^^^ which would be really good for the 2.7
  5. Apr 1, 2010 at 7:25 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
  6. Apr 1, 2010 at 7:27 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    i like electric fans. not so much for the power gain...there really isn't that much, but it makes the engine run a little less noisey
    it also free's up space at the front of the engine which allows easy access to accessories. plus belts are easier to change.
    my expierience was on an older chevy small block.
  7. Apr 1, 2010 at 8:03 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Had one on the 82 when it was a lowered convertible street machine.
  8. Apr 1, 2010 at 8:03 AM
    Smitherz
    Smitherz Active Member
    R
    Central Coast, Ca
    4.0L Tacoma
    Lexus aluminum 4.0 liter, quad cam, too much engine work to list, custom ECU etc etc. Self made and engineered 17" travel progressive and adjustable cantilever rear suspension. Donaho Racing front coilovers. Stripped interior with custom stereo being built. PRP Racing seats. Full Autometer gauges on
    You don't even need the shroud but it helps brace the fan if you do it right. DO IT. It makes a huge difference on the 2.7L.
  9. Apr 1, 2010 at 10:18 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Why would you not need the shroud? It's essential to ensure it pulls air through the radiator at stopped/slow speeds.
    Anyway, I've thought about doing it myself. Cleaner, easier to work with, don't run the risk of burning the fan clutch out and getting stranded on the side of the road, and it's safer to work around.
  10. Apr 1, 2010 at 10:24 AM
    81shark
    you run the risk of bad wiring. my wire burned or broke did something. anyways...it highway speed, it didn't need the fan to keep cool. at a stop tho, the temp would shoot right up and i could only stay stopped for a couple of minutes
    as for a big shroud, it's really that important, since the can comes semi shrouded. anything more than what comes with the fan isn't going to help much, or really be needed.
    i was running the flexalite dual fan set up.
  11. Apr 1, 2010 at 10:28 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I put the Flex-a-lite kit on mine (bring $$$$$), mostly to try and help the AC system. I didn't notice any performance or milage gains, but start-up is sure quiet!
  12. Apr 1, 2010 at 11:35 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    The one thing I don't like the flex-a-light fan is how the shround is smaller then the stock one. It looks so weird the way they designed it.
  13. Apr 1, 2010 at 1:08 PM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Keep the hood closed... ;)
  14. Apr 1, 2010 at 1:10 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    I want to put one on my 1st gen it makes a decent differnce in mpgs and helps with power a little.
  15. Apr 1, 2010 at 1:44 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Well the flexlight has a built in shroud. I thought you ment just attach an electric fan to it.... with no shroud. It would do very little. For example:
    At speed, it's fine. Idle or traffic, I got it up to near 240F (sbc v8). Yea, that was bad... had to stop in downtown Portland (was only about 85F out) and let it cool for about an hour. Also, the transmission cooler has been relocated to the front since that pic so... in before someone notices :p I still need to fix the fan/shroud bit though...
  16. Apr 1, 2010 at 1:50 PM
    81shark
    what is that in? that's an big shroud. i was running a dual fan set up and the whole thing was only a an inch or two think.
    i'm suprised it couldn't keep it cool at idle unless the air flow rating was too low
  17. Apr 14, 2010 at 12:38 AM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    I'm thinking about doing this to mine, but I'm a little concerned about the heat problems described by kyouto42. Is that a result of the shroud mismatch, or more of a fundamental problem with electrics in Tacoma's? Maybe a low cfm fan problem?
  18. Apr 14, 2010 at 6:16 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Not sure if you were directing this at the Flex-a-lite kit, or the home fabbed one, but my Tacoma with Flex-a-lite kit has not had any cooling problem since it was installed last August.
  19. Apr 14, 2010 at 8:44 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Does anyone have any data to show what gains there are from this mod?
  20. Apr 14, 2010 at 10:12 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Besides post 11? Not the detail data you wanted, but it is my data. :)
