Electric fans??
Discussion in 'Performance and Tuning' started by bigtaco07, Mar 29, 2011.
  1. Mar 29, 2011 at 8:05 PM
    bigtaco07
    bigtaco07 [OP] Member
    nathan
    07 tacoma with 6inch lift
    6 inch procomp lift 35 inch procomp tires 4 procomp off road lights all new stero equipment
    Is it possible to find the right size of electric fan that fits the taco and will it help any? And if any of you know what is the size of the 07 tacos radiator is?
  2. Mar 29, 2011 at 8:10 PM
    bigtaco07
    nathan
    Thanks, does it work well enough to spend the money and how easy is it install?
  3. Mar 29, 2011 at 8:12 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    X2 on the FAL (flex-a-lite)
  4. Mar 29, 2011 at 8:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    PD3 has a E fan on his truck, shoot him a PM.
  5. Mar 29, 2011 at 8:14 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    x2 I looked in his build thread and I didn't see any pics of it.
  6. Mar 29, 2011 at 8:15 PM
    bigtaco07
    nathan
    All thanks, good place to buy um?
  7. Mar 29, 2011 at 8:17 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I'm not sure where he got his.
  8. Mar 29, 2011 at 8:18 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    How much at summit whipper?
  9. Mar 29, 2011 at 8:21 PM
    bigtaco07
    nathan
    The kit would come with everything need to swap the fans out guys?
  10. Mar 29, 2011 at 8:23 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I don't know to be honest. Never installed one.
  11. Mar 29, 2011 at 8:24 PM
    tacoman007
    tacoman007 ignorance is bliss,
    Josh
    san diego
    07SR5ACCESSCABDEBAGED4X4
    alpine headunit,12'' rockford fosgate sub,ipod in g-box,drop in K&N, Marine decor,5100's front/rear,uniden pc68xl,radioshack PA speaker
  12. Mar 29, 2011 at 8:24 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    That's not bad. That's right in line with Jegs.
  13. Mar 29, 2011 at 8:26 PM
    bigtaco07
    nathan
    Though just a general question about toyotas engines, is it the fans on them(stock) make the motors sound a little clicky? Engine runs smooth, just has a small click since day one and I hear other toyotas with that sound too
  14. Mar 29, 2011 at 8:29 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No, that's a yota thing
  15. Mar 29, 2011 at 8:31 PM
    bigtaco07
    nathan
    Thought so, think takin the fan off and goin electrical will fix some of that noise then 98tacoma?
  16. Mar 29, 2011 at 8:32 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Maybe a little. It should free up a couple ponies though
  17. Mar 29, 2011 at 8:34 PM
    bigtaco07
    nathan
    Ya that's what I have heard, lookin for more miles per gallon, Im 19 lookin to spend a little to helP the truck and save some money down the road
  18. Mar 29, 2011 at 8:51 PM
    bigtaco07
    nathan
    Wow thanks, I'm hope I can do the in my garage over a weekend
  19. Mar 29, 2011 at 9:02 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
  20. Mar 29, 2011 at 9:07 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Another option would be to use a fan adequate for the vehicle, and build a custom setup. There isnt much more work involved and you'll have as good of, if not a better setup than you could buy in the FAL kit. I do like the FAL kit and its brackets for the fan, although i do not like their controller.
    I've used this particular Spal controller on a few custom off road setups before and it works flawlessly. One great advantage to is that when it kicks on, it starts at 50% power and progressively raising to 100%, depending on the low and high temperature set points you have programed into the controller. You can also wire the kit to where it will turn on the fan(s) when the A/C compressor is energized in order to keep cool air blowing even at a stand still in heavy traffic. On all of the setups I've wired, I have made a deutsch connector which acts as a jumper from the power inputs of the controller direct to the fan harness. This way in the event of a failure at the controller, you still have means of operating the fan in an always on mode. Cheap insurance and it only cost about $10 bucks.
    Controller
    http://www.spalusa.com/store/main.aspx?p=itemdetail&item=FAN-PWM-V3
    Fans
    http://www.spalusa.com/store/main.aspx?p=CategoryBody&c=FAEX
