Electric Heater Element?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tow-coma, Dec 6, 2017.
  1. Dec 28, 2017 at 2:09 PM
    #41
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Ford does that on the new transit connect, if you notice them they'l drive you insane
  2. Dec 28, 2017 at 3:46 PM
    #42
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    -35 this morning.... "Punkin" took 2 more revolutions than normal before she fired up.....don't blame her..!
    Put the heater to HI and defrost button ON...seat heaters ON.... fan on FULL.... Went back to get the "ole" lady... truck was throwing some heat by the time we got back.... about 4 minutes..+-
    It's a nice addition to have this electric heater in my 2016..!!
    Way to go Toyota...!!!! :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
    Kooltaco and Herniator like this.
  3. Jan 3, 2020 at 7:49 PM
    #43
    Bob K
    Bob K Well-Known Member
    Bob
    2017 TRD Off Road
    I have a 2017 TRDOR with the automatic climate control. I normally just set it to automatic and then set the desired temperature. The fan, then, adjusts speed as necessary.
    When you say "Blower switch on", is it considered "on" if the HVAC is in automatic mode? Or, do I have to manually position the blower switch to some particular speed in order to activate the electric heater?
  4. Jan 3, 2020 at 8:10 PM
    #44
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think as long as the Temp is set to "High" you should be good to go.
  5. Jan 4, 2020 at 4:21 PM
    #45
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    I think temp on high but i don't know if it has to be on auto also. and it need to be below a "certain" temp outside for it to go on, you cant check it at 45 out i think.
  6. Dec 7, 2020 at 7:31 AM
    #46
    MGM3Pedal
    MGM3Pedal Well-Known Member
    Rob
    Appalachian Mountains
    2017 MGM DCSB 6MT TRD Sport 4X4
    Just discovered this little gem this morning! I usually leave the fan off until the trucks up to temperature to prevent blowing cold air. Must have left it on this time and when I got to the truck a few minutes later, there was glorious warm air defrosting the windshield! It's the little things that make me smile... Temperature was around 29F with about half an inch of snow on the windshield when the truck was cranked.
    tonered likes this.
