electric impact wrench.. need impact socket?
Discussion in 'Garage / Workshop' started by ywen, Jul 1, 2010.
  1. Jul 1, 2010 at 9:06 AM
    ywen
    ywen [OP] Well-Known Member
    I just purchased a HF 1/2" electric impact wrench.. Do I really need to use impact sockets? It seems to me the electric version takes a second to spool up to full torque, whereas air-powered wrench has immediate sudden torque. So I think with air powered wrenches, you definitely need impact sockets, maybe not so with electric ones. Is that observation valid? What do guys recommend?
  2. Jul 1, 2010 at 9:07 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Subbed...
  3. Jul 1, 2010 at 9:14 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    go with the impact sockets. i have a milwalkee bad to the bone impact. i can do my entire truck twice (on and off) with one battery. i got it for tire changes at track days. it hits almost as hard as my air tool. impact sockets have three advantages when used with a air or electric gun.
    1. they are burly. i have had a regular one explode. not fun.
    2. they are unchromed. when a regular socket starts to go, it forms cracks. the cracks peel up the chrome. when was younger..i spun up a regular socket and pushed a tiny sheet of chrome into my hand...it was unbelievable how much it hurt. had to go to doc to have it removed. no chrome makes a socket easy to inspect for damage.
    3. that have that tiny hole in the side that locks the socket securely on a gun. try a regular socket and you will be reattaching it on the gun repeatedly.
    dont by HF impact sockets. my milwalkee kept smashing apart the 19mm.. i tossed the entire box,and bought a set from ACE hardware. bullet proof.
  4. Jul 1, 2010 at 9:15 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    I would get the impact socket.
  5. Jul 1, 2010 at 9:16 AM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    i recommend using impact sockets, but it depends on how tight you plan on getting the nuts / bolts and how tight the nuts / bolts are that you are removing. impact sockets are designed for impact, so if you're busting the lugs on your truck (for example) a regular socket might work for a little bit but it will eventually fail.
  6. Jul 1, 2010 at 9:18 AM
    ywen
    I only plan on using it to remove stubborn bolts and also loosening and tightening bolts, but not to torque it down.. I still plan on using my torque wrench for the final bit...
  7. Jul 1, 2010 at 9:20 AM
    Jester243
    Dan
    Spokane, WA
    ^^ this
  8. Jul 1, 2010 at 9:25 AM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    keep in mind that each time that impact hits it causes vibrations on regular sockets which are made of a brittle steel and can cause them to crack over time, or flake off that shiny coating. impact sockets are made of a "softer" metal allowing absorption of impacts.
  9. Jul 3, 2010 at 9:44 AM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    I have been using my craftsman sockets with my electric impact. The take a beating for sure, but if you break any craftsman socket you take it in, they give you a new one. I havent broken one yet, but I figure I might as well save my money and not get impact sockets.
    If I was a mechanic for a living, I would definitely have impact sockets
  10. Jul 3, 2010 at 9:58 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    After you shatter a chrome socket, and get a few pieces stuck in you, your observation will change drastically. It isn't the principle of breaking the actual socket, it comes down to the safety of yourself, and the people working around you. Sure you can probably get away with it, but all it takes is that one time. Impact sockets are not around for no good reason.
    Yes, you do need to use impact sockets on ANY impact wrench. Electric or air makes no difference.
  11. Jul 3, 2010 at 10:29 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I have broken half my Harbor freight set, so keep that in mind.
  12. Jul 3, 2010 at 12:06 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    The HF impact doesn't have enough power to break a regular socket
  13. Jul 3, 2010 at 12:08 PM
    lookylookitzadam
    Adam
    San Diego
    07 DC OffRoad
    That sounds amazing...i did not realize metal was a brittle material and that it could explode. :eek:
    Metal, even heat treated like sockets, is still considered a ductile material. It will stress, expand, and fracture, but will not explode. Hearsay is one thing, but show me proof and ill retract my comments.
    The worst you will do it break a piece of your socket off, damage the square mounting drive etc.
