Electric problems following trailer hookup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spennyblue23, Jul 30, 2025 at 11:39 AM.
  1. Jul 30, 2025 at 11:39 AM
    spennyblue23
    spennyblue23 [OP] New Member
    Wednesday
    2006 Tacoma TRD Off-Road
    Yesterday I purchased a 1996 trailer and plugged it into my trailer brake (already there when I purchased truck) and when I turned the truck back on I could not get it out of park. I used the manual override to get it out of park and drive home. But the check engine light was on, the airbag light was on, the A/C did not work, and my signals would not work. Of note, the left hand signal on the trailer did not work also. After disconnecting the truck from the trailer, the problems continued and still have to use manual override to get out of park. I couldn’t find any blown fuses, what could it be, and what should I do? Thanks all!
  2. Jul 30, 2025 at 11:49 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check your IG1, ACC, and STOP fuses.
    BKinzey, Torspd and spennyblue23[OP] like this.
  3. Jul 30, 2025 at 12:14 PM
    spennyblue23
    Wednesday
    Did not realize there was a fuse box in the cab! Found the IG1. It was indeed blown. Hopefully that fixes the problem. What should I do to prevent this from happening again when I want tow the trailer?
  4. Jul 30, 2025 at 12:21 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Need to figure out what is shorted/mis-wired on the trailer.
    If you have the factory tow package the only thing the IG1 Fuse powers at the trailer plug is the reverse light circuit which most trailers don't have so something is likely tied in there that shouldn't be if the trailer doesn't have backup lights.
  5. Jul 30, 2025 at 12:34 PM
    Clearwater Bill
    Billy
    Largo Florida
    Testing the truck side of the connection might be a good place to start. Does a test light show all the pins working properly?
    Some aftermarket harnesses / converters have caused some unusual problems when an electrical load was added.
  6. Jul 30, 2025 at 12:52 PM
    spennyblue23
    Wednesday
    Replaced the IG1 fuse. All the electrical problems fixed but the check engine light is still on…
  7. Jul 30, 2025 at 1:03 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You will need to clear the codes or wait a few drive cycles for them to clear.
