Electric Sliders
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Inferno!, Apr 17, 2020.
  1. Apr 17, 2020 at 4:28 PM
    Inferno!
    Inferno! [OP] Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    Installed some electric sliders. They deploy low and can be used as a step to get into the truck and they also retract for more ground clearance to clear the boulders.
  2. Apr 17, 2020 at 4:29 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Now this is a Friday thread! Good show OP
    Chunk, JKU3000, wilcam47 and 22 others like this.
  3. Apr 17, 2020 at 4:29 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I was thinking the same thing.
  4. Apr 17, 2020 at 4:30 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Well, he at least referenced ‘the electric slide’.
    rlx02, Rock Lobster, pinochle and 5 others like this.
  5. Apr 17, 2020 at 4:31 PM
    Speedytech7
    It's the most universal dance, accepted as custom at everything from sporting events to Jewish weddings.
    Blackbeard83 and Inferno![OP] like this.
  6. Apr 17, 2020 at 4:32 PM
    RushT
    North Texas
    It’s the new box step apparently.
    rlx02 and Inferno![OP] like this.
  7. Apr 17, 2020 at 4:33 PM
    Onwarrds
    Onwarrds @onwrrds
    Tyler
    Southern California
    2017 Black TRD OR 4x4 DCLB
    Fox 2.5 DSC Adjusters (Extended Travel), Camburg UCA, RCI Rear Bumper, Cali-Raised Zero Degree Step Rock Sliders (with filler plates), Softopper, TRD Pro Skid, Rigid, Baja and KC lights, H9 Headlight Upgrade.
  8. Apr 17, 2020 at 4:33 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I like that when you get hung up on rocks/bodies/etc, you can just press a button and lift up the truck.
  9. Apr 17, 2020 at 4:34 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Pro tip:
    if you get stuck in mud or hung up on rocks, you can deploy those to lift the truck up and out of whatever has you bogged. Works every single time. No-brainer.
    ponts, JKU3000, wilcam47 and 15 others like this.
  10. Apr 17, 2020 at 4:35 PM
    Inferno!
    El Dorado Hills
    Happy Friday! :yay:
    wilcam47 and Speedytech7[QUOTED] like this.
  11. Apr 17, 2020 at 4:35 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Retract for ground clearance? More like retract for more leg clearance to put all your groceries in at the mall
  12. Apr 17, 2020 at 4:37 PM
    TacoWdrd
    TacoWdrd Well-Known Member
    Shane
    Ohio
    2019 MGM TRD OR
    But do they shoot lasers?
    ponts, SR-71A, wilcam47 and 5 others like this.
  13. Apr 17, 2020 at 4:38 PM
    Inferno!
    El Dorado Hills
    Huh!? I installed these babies for protection in the little sluice box. And yes, they can be used to jack the truck if ever a flat.
    BLK_TRD, Blackbeard83 and boynoyce like this.
  14. Apr 17, 2020 at 4:44 PM
    Tacohumper13
    Tacohumper13 IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
    April 1st?
  15. Apr 17, 2020 at 4:45 PM
    0xDEADBEEF
    Worse. Friday.
    SR-71A, wilcam47, BigDinTexas and 2 others like this.
  16. Apr 17, 2020 at 4:46 PM
    Speedytech7
    It's a new horror Friday... Friday the 17th
  17. Apr 17, 2020 at 4:47 PM
    0xDEADBEEF
    Can't wait till TW Freaky Friday :ballchain:
    Inferno![OP] likes this.
  18. Apr 17, 2020 at 4:50 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    In for the shenanigans that are soon to follow
    MR E30 and Inferno![OP] like this.
  19. Apr 17, 2020 at 4:55 PM
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
  20. Apr 17, 2020 at 8:50 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Electric sliders . . . :rofl:
