Electric sounding noise help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomamod101$, Apr 23, 2024.
  1. Apr 23, 2024 at 11:25 AM
    Tacomamod101$
    Tacomamod101$ [OP] Blue Ridge mountain man
    2021 Tacoma SR White Double Cab
    Howdy folks, I have 2011 Tacoma TRD Off Road and have always heard this noise ever since I bought it, but am curious as to what it may be. It's the electric-like sound (not a "hummm" but more of a "ehhhhhhhhh" sound) and I am curious as to what may be causing this and if it is normal or concerning. This is the VVT-I engine with an ECT-I transmission. Could it be the electrical from the tranny? It's sort of in the background but stands out above all else (nearly equivalent to the Yoda/taco tick).
    It's been good for 100k miles but am curious what it could be due to my mechanical curiosity.
    All fluids are good, all components are working properly, no codes being thrown/no warning lights on the dash, and everything is tight and in good condition.
    https://youtube.com/shorts/W4FApxYIGfg?feature=share
    Kolter45 likes this.
  2. Apr 23, 2024 at 11:43 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like you may have a bearing on something on the belt drive going bad, may want to pop the belt off and spin all the pulleys.
    Kolter45 and Tacomamod101$[OP] like this.
  3. Apr 23, 2024 at 12:59 PM
    Tacomamod101$
    That was what I thought was happening but its been happening forever and never broke on me so that's the reason why I haven't fixed it yet lol. I can live with what's on the drive belt...
  4. Apr 23, 2024 at 1:15 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'd look at it sooner rather than later, if it throws/shreds the belt you could have bigger issues than just a bearing.
  5. Apr 23, 2024 at 1:32 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    Does the sound change when you turn the wheel?
    Have you unplugged the alternator & seen if the noise goes away?
  6. Apr 23, 2024 at 1:48 PM
    Tacomamod101$
    The noise doesn’t change pitch, and is unaffected by turning the wheel
    Unsure about the alternator
  7. Apr 23, 2024 at 1:48 PM
    Kolter45
    Denver, CO
    After starting the truck unplug the alternator to see if the noise stops
  8. Apr 23, 2024 at 1:50 PM
    Tacomamod101$
    I’ll try that tomorrow and see if it changes things.Thanks!
  9. Apr 23, 2024 at 2:02 PM
    Tacomamod101$
  10. Apr 23, 2024 at 3:38 PM
    Tacomamod101$
    Unplugged the alternator and still heard it. The sound does vary some when turning the steering wheel though
  11. Apr 23, 2024 at 3:49 PM
    Tacomamod101$
    The sound changes slightly, yes
  12. Apr 24, 2024 at 10:55 AM
    Kolter45
    Denver, CO
    It might be your power steering going out & thats why the noise changes when turning. Maybe new power steering fluid will help the pump last longer before it goes. I'd look at the fluid level
    Tacomamod101$[OP] likes this.
  13. Apr 24, 2024 at 4:19 PM
    Tacomamod101$
    power steering fluid is fine and at its proper level. No air, no leaks. I have the ect-I transmission and am thinking it could be the sound of it working properly. When driving, there’s no sound from turning the wheel and the sound seems to be directly correlated to rpm’s. When shifting to the next higher gear, rpm’s and go up, drop, and go back up as all cars do when going from one gear to the next. The sound in the recording is at idle, then when driving is correlated to the rpm’s. Everything sounds normal as far as I can tell and with all the shops I’ve been in the years past, nobody has ever thought the noise was of any concern (I have some very trustworthy shops :) )
    Also, the noise should fluctuate slightly with the turning of the wheel with rpm’s compensating for movement in the steering column. The noise sounds just like any other rpm related noise I’ve heard
  14. Apr 25, 2024 at 7:34 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    If you haven’t done so already, remove your drive belt and start the truck, see if the noise is gone. If it is, then the noise is definitely related to of the spinny bits on the front of the engine. Start spinning things by hand to see if you can determine which one it is. You can run the engine for a couple of minutes this way when cold, perhaps a minute or so when warm, with no adverse effects.
    Tacomamod101$[OP] and Dm93 like this.
