Electric Tacoma coming
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sand Dog, Apr 21, 2021.
  1. May 20, 2021 at 7:44 AM
    #801
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Well, sounds cool to me and well see how close they are to their statements when it comes out
    Its not going to do that, at least not the current models and they aren't made for those extreme conditions. However, I am sure down the line they will get there
  2. May 20, 2021 at 7:48 AM
    #802
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Depends on how many charging points are on his route though.
  3. May 20, 2021 at 7:49 AM
    #803
    stevesnj
    You can drive 470 miles on one tank of gas?
  4. May 20, 2021 at 7:49 AM
    #804
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I want to see how reliable the BEV 1ton pick up that is plowing snow and loaded down with salt running 18 hrs a day, in freezing temperatures performs as a whole vehicle.
  5. May 20, 2021 at 7:51 AM
    #805
    stevesnj
    They'd be reliable moreso than a petrol. You'd need to charge more often than putting fuel in it.
  6. May 20, 2021 at 7:51 AM
    #806
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    Grindstone likes this.
  7. May 20, 2021 at 7:53 AM
    #807
    ryanvar42
    None
    From the sounds of it not many.
    I could in my f150. I had the 35 gallon tank
    stevesnj[QUOTED] likes this.
  8. May 20, 2021 at 7:55 AM
    #808
    batacoma
    batacoma Truck Wars
    The ICE trucks that are being used now rot away from carrying and spreading salt, and those are not sitting on batteries.
    Can you run tire chains on a BEV?
  9. May 20, 2021 at 7:57 AM
    #809
    stevesnj
    I don't know the anti corrosion on BEV trucks or if they can use tire chains.
  10. May 20, 2021 at 7:59 AM
    #810
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    But what about wings, Steve? Can a BEV fly? Why isn’t anyone talking about whether they can handle a jacuzzi in the back like my 84 stretch limo? WHY DON’T YOU KNOW?!
  11. May 20, 2021 at 8:00 AM
    #811
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    No more:
    MAF
    O2 sensors
    Air pump
    Fuel tank
    Fuel pump
    Fuel line
    Fuel pressure sensor
    Fuel rail
    Fuel injectors
    Spark plugs
    Coils
    Alternator
    Starter
    Oil pan
    Oil filter
    Oil pump
    Air box
    Throttle body
    Intake manifold
    Valve covers
    Valves
    Lifters
    Cams
    Pistons
    Rings
    Cranks
    Lobed crankshaft
    Shitloads of bearings
    Exhaust manifold
    Catalytic converter
    Exhaust pipe
    Muffler
    Transmission
    More shitloads of bearings
    Flywheel
    Clutch plate
    Clutch master cylinder
    Throw out bearing
    in other words, a shit load of sensors, seals, gaskets, lubricants, and moving parts all going in different directions that generate less acceleration even now.
    05Taco4x4, taco_rhyno, OZ TRD and 3 others like this.
  12. May 20, 2021 at 8:01 AM
    #812
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Tesla sells these “chains” for their cars: https://shop.tesla.com/product/model-s-snow-chains
    stevesnj likes this.
  13. May 20, 2021 at 8:03 AM
    #813
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Besides the obvious current issue of range there's no reason the rest of this couldn't happen.
    And that truck has an engine that requires huge volumes of air to move through and has way more potential spots for salt/water to get in yet its sealed up to run fine in that environment. But you don't think the same can be done to a sealed electric motor? Again, if you can seal a gas tank why can't you seal a battery?
    Electric motors have been working in industrial applications for over a 100 years at this point. You have electric motors all over your truck today that work fine.
  14. May 20, 2021 at 8:03 AM
    #814
    batacoma
    batacoma Truck Wars
    Any commercial vehicle builder probably wants to address and solve any potential issues.
    Right now, a business owner who's entire business revolves around a commercial truck would need to have 2 BEVs to replace their 1 ICE truck.
    One to use, and another sitting on the charger.
  15. May 20, 2021 at 8:03 AM
    #815
    stevesnj
  16. May 20, 2021 at 8:04 AM
    #816
    stevesnj
    In some states, at least in NJ, no state inspection required for full BEV vehicles.
  17. May 20, 2021 at 8:05 AM
    #817
    stevesnj
    You should bring this up to Ford and othe EV truck Mfgs.
  18. May 20, 2021 at 8:05 AM
    #818
    batacoma
    batacoma Truck Wars
  19. May 20, 2021 at 8:09 AM
    #819
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Steve, I love you. You’re so persistent! If I still live in Brooklyn I’d cross the river and toss back a craft beer with you in Freehold. But I’m too far right now since my Tacoma only gets 450 miles to the tank (I can’t stop to refuel), so there’s no way to have a gam. Alas.
    Lt. Dangle and stevesnj[QUOTED] like this.
  20. May 20, 2021 at 8:10 AM
    #820
    batacoma
    batacoma Truck Wars
    I'm sure Ford has thought of this.
    I can't realistically see BEV being viable with out the support of ICE or Hybrid vehicles.
