Electric Vehicles
Discussion in 'Electric Vehicles (EVs)' started by steel wheels, Sep 5, 2022.
  1. Sep 21, 2022 at 8:54 AM
    #481
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Use a Transmission brake for now? :notsure: Launch control for Austin traffic.
    https://youtu.be/-xIthdaOLeQ
  2. Sep 21, 2022 at 9:04 AM
    #482
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    Yea you just get up at 1 am and 5 am and borrow the neighbors cord and they are none the wiser except they can’t figure out why their car was charging so slow
  3. Sep 21, 2022 at 9:09 AM
    #483
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    I would expect an infrastructure to arise somewhat akin to parking meters - wired poles regularly spaced in places where electric vehicles are parked.
    We also have an extensive wireless infrastructure already in place and growing, so a charging service would likely utilize it.
    Usage would be subscription based, with a pay-per-charge option available. Plug in, scan the meter with the app, and the app shows the progress. If the cable is disconnected the "session" ends, preventing an electron thief from charging up another vehicle on someone else's session. The car's owner would also be notified via the app that their session was interrupted, whereupon they can grab their bat and go to town on the dickhead who unplugged them.
    These system behaviors aren't that difficult to code.
    What will be harder is gathering the investment for installing the initial infrastructure...which after a short period will then fund further installations. Residential streets, strip mall and shopping center parking lots, parking garages - they'll all be able to make supplemental income by also joining the charging game. By this point it will be harder to find a place to park that doesn't have charging stations in at least half of it than to find one without. Simply trench, set your stations, franchise your meter collection, and "join the grid."
    If a neighborhood doesn't have this expanded capability, there will still be an overwhelming preponderance of public options. Charge your car while you're at work or at the grocery store, and not worry about having to charge at home because you'd still have a 90% - 95% charge and a remaining 300 mile range just from picking up groceries and a charge on the way home.
    C'mon, gimme a hard one.
    Society will figure all of this out as the opportunities present themselves.
    23Skidoo and stevesnj like this.
  4. Sep 21, 2022 at 9:17 AM
    #484
    YatYas1833
    YatYas1833 Well-Known Member
    22 WHITE TRD OFFROAD 4x4 DCSB
    King 2.5’s with adjusters from accutune front and rear, 88 rotors rear add a leaf, Camburg X-joint UCA’s, Factory style trd pro 16” wheels with 0 offset, 285/75/16 KO2’s, pro grille, Front bumper viper cut, trd front skid plate, full RCI under skid plates, Cali raised trail sliders, exhaust cut dump, KDMax 10.0 tune
  5. Sep 21, 2022 at 9:19 AM
    #485
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    I plug it in when I get home and I unplug in the morning and it's full... idk?
    Kremtok[QUOTED] likes this.
  6. Sep 21, 2022 at 9:20 AM
    #486
    .劉煒
    Not sure about you but the R4P will tell me if the car is unplugged.
  7. Sep 21, 2022 at 9:31 AM
    #487
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    What’s the Texas one look like?
    b_r_o, CaptAmerica and 23Skidoo like this.
  8. Sep 21, 2022 at 9:37 AM
    #488
    CaptAmerica
    Cap
    That was a rough week - don’t remind me.
    TheCochese[QUOTED] likes this.
  9. Sep 21, 2022 at 9:38 AM
    #489
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    We couldn’t even get gas.
  10. Sep 21, 2022 at 9:39 AM
    #490
    23Skidoo
    Paul
    meme
    Had to pay cash for beer.
    VE7OSR likes this.
  11. Sep 21, 2022 at 9:45 AM
    #491
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Already have that one figured out in locales where it gets cold, very cold. - plug ins for block heaters - at home, at work, at hotels, etc... a technical challenge with a solution already available.
  12. Sep 21, 2022 at 9:46 AM
    #492
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    a trailer for the genset with a rubbermaid garbage can filled with fuel, gravity feeding the 5kW generator.
    scocar and TheCochese[QUOTED] like this.
  13. Sep 21, 2022 at 9:48 AM
    #493
    CaptAmerica
    Cap
    Only if the garbage can is on a rickety unregistered trailer with wonky wheels and shorted-out brake lights.
    #rollingMOAB
    23Skidoo likes this.
  14. Sep 21, 2022 at 9:49 AM
    #494
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Is there any other kind of home grown trailer in Texas?
    CaptAmerica[QUOTED] likes this.
  15. Sep 21, 2022 at 9:50 AM
    #495
    23Skidoo
    Paul
    meme
    Nobody has ever died from huffing electricity.
    VE7OSR likes this.
  16. Sep 21, 2022 at 9:53 AM
    #496
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    The test for those trailers is to fill them with landscaping gear, then see how many latinos can ride in the pickup truck box and trailer, in the empty spaces.
    I shit you not, saw that on I20 between Dallas & Ft Worth, not the trailer, but a landscape company pickup truck towing a trailer, with 4 people in the back of the open pickup truck box, in between a lawnmower and hand implements.
  17. Sep 21, 2022 at 9:54 AM
    #497
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    I'd disagree. Licking a live electrical conductor does not end well; and many a copper thief have found out its a bad idea.
    Launch Mini likes this.
  18. Sep 21, 2022 at 9:56 AM
    #498
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    23Skidoo and VE7OSR[QUOTED] like this.
  19. Sep 21, 2022 at 10:09 AM
    #499
    TheCochese
    Post this in the right forum, and it’s challenge accepted.
    23Skidoo[QUOTED] and CaptAmerica like this.
  20. Sep 21, 2022 at 10:15 AM
    #500
    stevesnj
    23Skidoo and TheCochese[QUOTED] like this.
