Electric Vehicles
Discussion in 'Electric Vehicles (EVs)' started by steel wheels, Sep 5, 2022.
  1. Dec 21, 2023 at 12:44 PM
    #601
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Shh, don't let our resident "investigative journalist" find that out
    jsi[QUOTED] likes this.
  2. Dec 21, 2023 at 3:11 PM
    #602
    jsi
    jsi Well-Known Member
    native earthling
    I've blocked him, but I think this is from one of his posts. Maybe he's opened his eyes to the fact that gas cars are 3 thousand times more likely to catch fire than an EV. At least that's what his post shows.
  3. Dec 22, 2023 at 3:59 PM
    #603
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The number l remember seeing in that article was 64 percent, but it may have included other things like the cars being burned up in house fires, garage fires, forest fires etc...
  4. Dec 23, 2023 at 9:25 AM
    #604
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    the statistic should be viewed as a per capita, ie # of ICE vehicle fires as compared to total on the road, and the same for Hybrids, EV, as there is considerable disparity in total #s of vehicles in each fuel type category. I think that would give a better picture of the risk.
    Duh EDIT I see the correct post now.
    Gunshot-6A likes this.
  5. Dec 23, 2023 at 9:31 AM
    #605
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    True. Although I will say in Seattle metro, the % of Teslas on the road vs the general population is def higher than many areas I have lived (DC/LA/SLC) and def still notice that any vehicle fires I do come across are ICE, usually aged big 3.
    I'm no EV enthusiast, but any fire risk they do have is almost always a secondary from something else like impact, etc.
  6. Dec 23, 2023 at 9:37 AM
    #606
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    "The times they are a changing".
  7. Dec 23, 2023 at 11:44 AM
    #607
    jsi
    native earthling
    The Duh's on me . . and you are right I compared the actual number of EVs today with gas cars and 3,000 times is correct but makes me guilty of twisting the numbers. My bad and I apologize. I hate number twisters and I will strive to think things through in the future. This is a case where I should have understood the chart itself before posting anything. After further inspection the infographic from the resident troll is its own exercise in number twisting. Comparing car fires to the number of cars sold is a stupid measurement. The article linked below goes into greater detail, but the TLDR is the infographic is bullshit that isn't based on any numbers tracked by reputable organizations. On it surface it says EVs are much less likely to catch fire. However the numbers appear to be made up so take them with a 50 pound bag of water softener salt. I'm also going to edit the original post.
    https://www.caranddriver.com/news/a40163966/cars-catching-fire-new-york-times-real-statistics/
    Gunshot-6A and doublethebass like this.
  8. Dec 23, 2023 at 12:11 PM
    #608
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    For some, the goal is obfuscation, not clarification
    Guess which one requires more effort?
    jsi and doublethebass like this.
  9. Dec 27, 2023 at 7:18 AM
    #609
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    I just read an article on Motor Trend about a Lightning Nightmare Road Trip and this issue stood out.
    “Starting with the battery charged to 100 percent and the range meter reading an ever-optimistic 324 miles (as we've covered previously, Ford thought it would be a good idea for the Lightning to display best-case EPA-rated range when charged above 80 percent on either a Level 1 or 2 charger), we cued up our preplanned FordPass route in the Lightning. Before we even pulled out of the driveway, our range meter dropped down to 200 miles, and "Range Revised Due to Route" flashed on the instrument cluster.”
    Why are these manufacturers allowed to give out false ranges?
