Electric vs Gas Cost
Discussion in 'Electric Vehicles (EVs)' started by Builder1, Jan 26, 2023.
  1. Jan 26, 2023 at 5:23 PM
    #141
    Couesfanatic
    Couesfanatic Well-Known Member
    These guys did the test. It's not my math. https://www.youtube.com/@TFLoffroad/videos
  2. Jan 26, 2023 at 5:26 PM
    #142
    perterra
    perterra Well-Known Member
    Tejas
    Horses for courses, I would never think of an EV as an ideal off roader, nor would I think an ICE as a ideal short trip commuter.
  3. Jan 26, 2023 at 5:27 PM
    #143
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
  4. Jan 26, 2023 at 5:29 PM
    #144
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :notsure:
    Miracles can happen?
    Is the Taco, the truck of the year? :rofl:
  5. Jan 26, 2023 at 5:31 PM
    #145
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Yea what charger does 11.5kw at home ? That’s pretty high. Mine was 5.5-7kw. Also no one would go 0-100 should be 20-80 or so. So prob about the same amount of time
  6. Jan 26, 2023 at 5:34 PM
    #146
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    A lot of them do. Tesla’s and Rivian’s chargers are both 11.5kwh capable as are many others from outside manufacturers. I fully understand that no one would go 0-100% though.
  7. Jan 26, 2023 at 5:38 PM
    #147
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    HA thats interesting, i never knew that! but you're still that guy at the party..
    crashnburn80[QUOTED] likes this.
  8. Jan 26, 2023 at 8:04 PM
    #148
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I use my 95 Corolla for daily work commute. I fill it once a month for 40 bucks. Granted I have a very short work commute. Cost for fuel per year about 480. You are ahead 326.00. Cost to insure my Corolla 22.00 per month. Cost per month to insure your Tesla? Monthly payment for mine 0.0. Payment for your Tesla? This is why these kinds of comparisons are pointless because there is no baseline. Your operating costs are lower then driving a trx but significantly higher than mine so how can you say electric saves you anything over gas when the only way to calculate it is based on what you’re comparing it to?
  9. Jan 26, 2023 at 8:08 PM
    #149
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    It should be obvious beyond the need for discussion that a nearly 30 year old sedan is cheap to operate and insure. The cheapest vehicle is almost always the one you already own. Someone shopping and comparing vehicles isn’t likely to be looking at a choice between a ‘95 Corolla and a ‘22 Tesla.
    minium likes this.
  10. Jan 26, 2023 at 8:10 PM
    #150
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I have the Prius example earlier but you can get a 2022 Corolla for like $20k.
    I think the point is that you need a baseline to compare and most people aren’t comparing apples to apples. To his point why would you compare a RAM truck to a Tesla model 3. I think aligns with your point; people shopping for a Tesla are likely not comparing it to say an LC200…
    John3976 and MadKatt like this.
  11. Jan 26, 2023 at 8:11 PM
    #151
    Couesfanatic
    its more real life charging they are doing, not math
  12. Jan 26, 2023 at 8:23 PM
    #152
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    A more like for like comparison would be with a Camry rather than a Corolla. In that case the Toyota is still cheaper, $26.2k vs $30.3k for a Tesla model 3.
    But yeah, the point I meant to make was that the comparison only works when comparing similar size, purpose and age vehicles.
    JoeCOVA[QUOTED] likes this.
  13. Jan 26, 2023 at 8:27 PM
    #153
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    In that case they are just making a point of bad information to get more clicks or something. The portable charger included with the Hummer will charge at 7.7kwh on a 220 outlet which is still far less than 4.5 days.
  14. Jan 26, 2023 at 8:33 PM
    #154
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    the 2024 tacoma might be a etruck
  15. Jan 26, 2023 at 8:35 PM
    #155
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I run a NEMA 14-50 at home. I could be fully charged (I never let it get very low as I plug it in) and it’s set to charge in off-peak..prob would only take a couple of hours..all done before I’m ready to leave, with the cabin temp set to where I tell it to be. If you SC it I’ll be a TON faster depending which version SC you are utilizing.
    If you’re using the standard home outlet like mentioned, ya probably around there or longer depending on the size of battery and where you start charging (% wise)
  16. Jan 26, 2023 at 8:37 PM
    #156
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think the only E-Truck they have planned is the Hilux Revo.
  17. Jan 26, 2023 at 8:39 PM
    #157
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Note that I never said new electric cars save anything over a 25+ year old economy car. I said operating costs are lower. Keeping an old car you already own outright will almost always be far cheaper than buying something new whether it is gas or electric. If you are in the market for buying a new car and comparing gas vs electric of similar equivalent priced vehicles, electric is cheaper to operate.
    People get way too caught up in micro-scrutinizing the cost argument in EVs. Do they do that when comparing ICE vehicles? Not really. Car enthusiasts tend to buy what performs best and whatever they like best for a given price bracket. I did not buy my Tesla to save money. I bought it because it is an absolutely incredible performance car.
    Your example is comparing a 25+ yr old economy car to a car that competes with supercars is also obviously an unjust baseline to your point. Ferrari, Lamborghini, McLaren are close in 0-60 performance to an M3P, lightyears faster than an even new Corolla, much less one decades old, so maybe costs and insurance rates should be compared to those supercars? Makes the Tesla look like a screaming deal. The answer to saving money will almost always be keep driving what you have till you drive it into the ground. Obviously the Tesla will cost more than the 25+ year old sedan, but is far cheaper and more practical than a supercar.
    In terms of the App calculation, they use a 30mpg sedan for the savings calculation. Realistically that was way better than my supercharged Gladiator that required premium and got 12mpg. Comparing to a 30mpg sedan I'd actually say is tilting the table to ICE in the comparison for the M3P, as sedans that have this performance level are getting nowhere close to that kind of economy.
  18. Jan 26, 2023 at 8:44 PM
    #158
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Gas was over $9.00 a gallon here in October for regular.
    Electricity costs me $0.093 per kWh.
    A tesla model 3 uses about 15 kWh/100km's, or $1.37 per 100km's. Let's be generous and say $2.00
    The equivalent ICE would get about 8 litres/100kms or 2.2 gallons per 100kms/62miles, or $20 in fuel.
    Why in the Fu%$ would I choose to spend 10X as much on fuel and support some multinational vs. the locally generated hydro power plants?
    Big Oil can suck it.
  19. Jan 26, 2023 at 8:44 PM
    #159
    JoeCOVA
    Joe
    Colorado Springs
    Please. Electric cars are fast but make no mistake, they don’t “compete” with super cars. People don’t buy Ferraris because they are fast, you can make any car fast.
    But for the record an M3P is about twice as slow as an 812, 0-200kph
  20. Jan 26, 2023 at 8:48 PM
    #160
    Woofer2609
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    If there was an equivalent to the Chevy Volt but sold in a truck body with awd/4wd, they'd sell more than they could make.
    crazysccrmd likes this.
