Electric wiring question...
Discussion in 'Technical Chat' started by Montana1999, Sep 27, 2020.
  1. Sep 27, 2020 at 8:21 PM
    Montana1999
    Montana1999 [OP] Member
    Patrick
    2020 TRD Sport
    Hey everyone...I just installed a RedArc Tow Pro brake controller in my new 2020 TRD Sport. I had the right wiring harness and it seems pretty simple, but I'm not good with electrical system stuff. I think this is a super simple question, but again, I'm a newbie at this. I connected the white ground wire to a bare nut that was clean, no rust, and no paint. Is that the way you do the ground wire? Also, is there any way I will fry my truck's electrical system if I did something wrong? Any words of encouragement would be helpful :) Thanks!
  2. Sep 27, 2020 at 8:25 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Yes you ground the brake controller because the factory wiring harness has a very wimpy 20-22 gauge wire for ground feeding into that connector. So, any good metal contact is likely perfect, unpainted is better than painted, you can test with a multi-meter but it's really hard to mess up a ground.
    Assuming you purchased the proper harness or your controller came with one, there's very little risk. Worst possible scenario has you popping the brake controller fuse. Double-check compatibility between controller and harness if you like but there really shouldn't be any way to mess this up.
    I've tinkered with a Tekonsha harness myself so I know the connector fairly well based on info from Caribe Makaira who knows every connector on a first name basis.
