electrical / BCM help
Discussion in '1st Gen. Tacomas (1995-2004)' started by gbollom, Apr 8, 2017.
  1. Apr 10, 2017 at 1:51 PM
    gbollom
    gbollom [OP] Well-Known Member
    Weatherford Tx
    01 xcab TRD 4x4 5spd
    No, but maybe I should lol
    tcjacado[QUOTED] likes this.
  2. Apr 10, 2017 at 1:52 PM
    tcjacado
    tcjacado Well-Known Member
    I never posted a harness for you. BTW I don't understand the abbreviation of all the components so there I am at a loss.
  3. Apr 10, 2017 at 1:55 PM
    tcjacado
    Try that after a beer and and some thinking of how the electrical is suppose to run. Also you didn't happen to take a picture of it before you tore it apart??
  4. Apr 10, 2017 at 1:55 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    let look at what I posted
  5. Apr 10, 2017 at 2:03 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Here's a file for older ones see if it matches up.
  6. Apr 10, 2017 at 2:08 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    the door locks switch's work by completing the ground
  7. Apr 10, 2017 at 2:17 PM
    gbollom
    Weatherford Tx
    Mine still does not have pin #6 on the BE-50 page. For some reason my harness and switch is different than this one also
  8. Apr 10, 2017 at 2:20 PM
    gbollom
    Weatherford Tx
    I was able to get continuity between the pins based off of switch position, but I only have 3 pins instead of 4 for the door lock function in the window switch panel and harness.
  9. Apr 10, 2017 at 5:05 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    That's all there is #1 is empty
  10. Apr 10, 2017 at 5:06 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    This one has pin 6 for the window lock out an double cabs. So you wouldn't have that. pdf file above 041dlc.pdf
    tcjacado likes this.
  11. Apr 11, 2017 at 11:48 AM
    tcjacado
    Did you get it fixed?
  12. Apr 11, 2017 at 7:14 PM
    gbollom
    Weatherford Tx
    Didn't mess with it anymore today. Got frustrated yesterday and gave up for a little bit before a burn the damn thing lol
  13. Apr 11, 2017 at 7:29 PM
    tcjacado
    Calm down. It worked before. It will work again. Just go back through process step by step. You will find it.
    gbollom[OP] likes this.
  14. Apr 11, 2017 at 7:58 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Remember it works off of grounding by the switch. The switch doesn't send battery power to the motor.
  15. Apr 11, 2017 at 8:07 PM
    #35
    mechanicjon
    Jon
    Scottsdale Arizona
    If the PS locks with Drivers switch but DS doesn't. There has to be a problem with the lock actuator or wiring to it. They're all tied togeather. With door lock switch in locking postion. Hold it down and check for power at lock actuator plug.
  16. May 15, 2017 at 9:34 PM
    #36
    tcjacado
    Did you ever figure this out op?
    mechanicjon likes this.
  17. May 16, 2017 at 9:14 AM
    #37
    gbollom
    Weatherford Tx
    Haven't messed with it since. Since my son was born it just got shuffled down the "to do" list. Rocking manual lock on the DS door for now.
    Pretty sure it's in the wiring harness though. The switch definitely works, and the motor will turn with voltage applied directly to it, just haven't had time to trace the door harness out of the door and into the relay box behind the lock panel yet
  18. May 16, 2017 at 11:12 PM
    #38
    angeldavid216
    angeldavid216 Well-Known Member
    Angel
    Orange County, California
    TACOFJ_BUILDS
    2011 4x4 DCLB TRD SPORT: TRD Skid plate Satoshi Grill Bushwacker fender flares Camper Shell Bed mat Hankooks M/T 265/70/17 2008 4x4 FJ Cruiser Trail Team: White TRD Exhaust General Grabbers 265/70/16
    Sorry, been a long time troller on here...
    But is this common for 2nd gens?
    I am in the same scenario as OP. This just happened to me the other night... I assumed the issue was a fuse problem, but 2 blown fuses later; the issue remains to be unknown...
    Not a priority right now. Just annoying to manually lock/unlock doors, when you have 2 little ones to buckle in.:annoyed:
    OP good luck on the find, and congrats on the little one...:cheers:
  19. May 18, 2017 at 4:14 AM
    #39
    gbollom
    Weatherford Tx
    Pretty sure the motor in the actuator is the commons problem with the second gens. $6 part on ebay
    #39
  20. Jun 4, 2017 at 9:21 PM
    #40
    tcjacado
    Have we ever figured this out?
