Electrical/computer freak out -plz help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thecooklook, Jan 30, 2024.
  1. Jan 30, 2024 at 4:49 PM
    thecooklook
    thecooklook [OP] Member
  2. Jan 30, 2024 at 4:58 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You got a loose battery clamp or loose ground somewhere.
    Chew, PJTree and RustyGreen like this.
  3. Jan 30, 2024 at 5:22 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    ^^^ Start here ^^^
    You want to get this addressed sooner rather than later - that on/off/on/off cycling can damage components and these trucks have very sensitive electric systems.
    Chew likes this.
  4. Jan 30, 2024 at 5:27 PM
    Pierce2006V64x4
    Pierce2006V64x4 Member
    Pierce
    1996 Tacoma 3rz Regular Cab
    12 inch Subwoofer Aftermarket radio
    im having the same issue currently still cant figure out whats wrong, new terminals, new battery, alternator, alternator cord, clutch safety sensor, souldered all of my radio connections, changed fuses, nothin workin, truck will die while driving, it threw an ignition coil code p1300 so i will be replacing that soon
  5. Jan 30, 2024 at 5:29 PM
    Pierce2006V64x4
    Pierce
    same issue without the cruise control, it just happens while driving
  6. Jan 30, 2024 at 5:34 PM
    ET_Quila
    ET_Quila Well-Known Member
    ET
    Ohio
    2033 4Runner Trd Off Road
    I've seen this before in a x-files episode. Definitely aliens..as others have stated check your battery terminals first. You may also want to inspect the wiring harness in the engine compartment for signs of mice or rodents.
    Gearhead223 and koditten like this.
