Electrical dilemma...trying to get ideas on where to start.
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoHank1998, Jul 31, 2019.
  1. Jul 31, 2019 at 7:17 PM
    TacoHank1998
    TacoHank1998 [OP] Well-Known Member
    Will
    Panama City, FL
    1998 Green Tacoma Base
    So... none of my marker lights work. I have headlights, brake lights, blinkers... etc but the taillights, tag lights or parking light dont seem to work.
    Switch?
    Also... I did swap to a newer cluster... could i have messed something up doing that?
    Any suggestions welcome.
  2. Jul 31, 2019 at 10:24 PM
    Glamisman
    Glamisman Well-Known Member
    1998 to 2000 are uspposed to be the same electricaly. This is for a 2000 MY tail light and illumination
  3. Aug 1, 2019 at 12:44 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Did this problem start when the gauge cluster was swapped??
    Quite easy to cause a fuse to open unless the battery was disconnected
    I would start with the simple the tail light fuse and the panel fuse if those are intact check if your tail light relay is closing like it should .
  4. Aug 1, 2019 at 5:49 AM
    TacoHank1998
    Will
    Panama City, FL
    Wait... tails and headlights are on separate fuses?!
    And I'm not sure when it started... just got pulled over last night for it though.
    @Glamisman ... thanks for diagram.
  5. Aug 1, 2019 at 5:56 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Have you confirmed that the bulbs/lamps are working?
    If the bulbs are good. An electronic Hail Mary, check the grounds.
