Electrical Engineering help
Discussion in 'Sports, Hobbies & Interests' started by DanGer, Jun 3, 2009.
  1. Jun 3, 2009 at 10:17 AM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Can anyone familiar with ammeters and voltmeters help clarify what they are?
    I know voltmeters are in series while ammeters are in parallel, but I dont't understand the point of them or why they exist.
  2. Jun 3, 2009 at 10:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    UH...............voltmeters measure voltage and ammeters measure ampherage.
  3. Jun 3, 2009 at 10:22 AM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    Are you sure is not the other way around, voltmeters in parallel and ammeters in series, if you are talking about the measurement tool, one measures voltage the other current.
  4. Jun 3, 2009 at 10:23 AM
    thecoldone06
    thecoldone06 Well-Known Member
    Voltmeter will measure how much voltage is going through a wire. Making sure you have 120 volts at a socket, for example.
    Ammeter measures how much current there is moving through a circuit.
  5. Jun 3, 2009 at 10:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    x2
  6. Jun 3, 2009 at 10:26 AM
    DanGer
    I mean when added as resistors to a circuit. Idk I didn't provide a good description of my issue. Let me talk to my professor and reread some text
    This is the slide from out lecture
    E theory.jpg[​IMG]
  7. Jun 3, 2009 at 10:27 AM
    epa4wd
    Eduardo
    2019 SR
    If you have a bigger image I can help you out, I can't see the slide its to small.
  8. Jun 3, 2009 at 10:28 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I think you may have that backwards. ;)
    A voltmeter measures the potential difference in voltage between two points in a circuit. Measuring DC voltage for instance, is typically done with the black lead on the ground or reference and the red lead on the voltage to be measured.
    An current meter is inserted in line as the current must flow through the meter. If the current meter is inserted in parallel to the circuit component, then all the current will flow through the meter and not through the circuit component. Current always flows through the path of least resistance. The leads on multimeters have to be plugged into different holes when measuring current. If not, you'll blow the meter up.
    Hope this helped. :)
  9. Jun 3, 2009 at 11:09 AM
    DanGer
    Actually you post made me think my way through it. The pictures she drew in our lecture were talking about how the Shunt resister in parallel is typically tiny to allow the maximum current to flow through. I am still a little iffy on all the galvanometer/D'Arsonval movement stuff, but she said there wont be any workout problems on the exam tomorrow
  10. Jun 3, 2009 at 11:40 AM
    afd23a
    The Dynamo of Dixie
    Sorry, my reply was geared towards the use of a DMM. I didn't realize you were talking about the analog type of meter. DMM's have the shunt built in and the meter compensates for the shunt value in it's readings. I'm sorry I haven't' worked hardly at all with those type meters, always DMM's. It sounds like you would apply a ratio when using the shunt though.
    By the way I'm not an EE, so I don't have all the design knowledge. I just repaired stuff for a few years.
  11. Jun 3, 2009 at 4:27 PM
    spp
    spp OC, Kalifornia
    OC California
    Ampmeters can also be clamp on type that surround the conductor with a coil to use inductance to read the amperage flowing through the wire instead of interupting the circuit and having the current flow through the meter.
    That's how we take readings on large conductors in the electrical business.
  12. Jun 3, 2009 at 4:44 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
  13. Jun 3, 2009 at 4:47 PM
    hillbillytaco
    hillbillytaco HOT!!
    Jeremy
    westbyGodvirginia
    06 impulse red trd off road dc v6 6spd
