Electrical Gremlin On My Back! HELP!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by J4R, Jun 1, 2024.
  1. Jun 1, 2024 at 6:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Well, that throws us a curve.
    I’ll have to look at diagrams for a T4R, let me look and get back to you.
    Gunshot-6A likes this.
  2. Jun 1, 2024 at 6:24 PM
    TnShooter
    Deogee
    STOCK
    Might as well share it. That way we are all working off the same diagrams.
  3. Jun 1, 2024 at 6:28 PM
    J4R
    J4R [OP] Well-Known Member
    2005 4R 4.0 4X4
    2009 Tacoma motor
    I know it my bad man it wasn't easy admitting my fubar there on that. Sorry yall.
    Uploading diagram now.
    TnShooter likes this.
  4. Jun 1, 2024 at 6:37 PM
    TnShooter
    Deogee
    STOCK
    Interesting. The ECM directly controls power on the T4R.....
    Which tells us a lot.
  5. Jun 1, 2024 at 6:43 PM
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    Grrrr dammit says it won't let me upload "due to low memory" Guess I could do screenshots or something if that helps
  6. Jun 1, 2024 at 6:44 PM
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    What you thinking with your new findings
  7. Jun 1, 2024 at 6:46 PM
    TnShooter
    Deogee
    STOCK
    We have a power issue to the ECM.
    Power or Ground either one.
    J4R[QUOTED][OP] likes this.
  8. Jun 1, 2024 at 6:49 PM
    TnShooter
    Deogee
    STOCK
    Do you have power to the 20 EFI fuse?
    Gunshot-6A and J4R[OP] like this.
  9. Jun 1, 2024 at 6:52 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Well this got complex in a hurry, we can probably solve it but I need to sit down with wiring diagrams and look this over.
    Just so we're clear on what we're working with we have a 2005 4wd 4runner with a 2009 Tacoma engine and an 07 2wd 4runner engine harness correct?
    Gunshot-6A, winkel and TnShooter like this.
  10. Jun 1, 2024 at 6:54 PM
    TnShooter
    Deogee
    STOCK
    This one is going to be fun.
    But let's hope it's a power issue
    winkel and Dm93[QUOTED] like this.
  11. Jun 1, 2024 at 7:00 PM
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    I agree on the power or ground ECM.
    I'm pretty sure on the power to 20A EFI but let me go double check rite quick to confirm.
    Yesir
    2005 T4R
    2009 Tacoma motor
    2007 T4R harness
    My bad on the complexity but you are definitely appreciated more than you know...much obliged.
    Well get it figured out one way or another thanks to your expertise.
  12. Jun 1, 2024 at 7:03 PM
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    Power to 20A EFI confirmed
  13. Jun 1, 2024 at 7:08 PM
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    ECM PINOUT here if that helps
  14. Jun 1, 2024 at 7:10 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I have TIS so I can get whatever we need, I just don't have time to ATM. Give me an hour or so.
  15. Jun 1, 2024 at 7:10 PM
    #35
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    Rite on thanks
  16. Jun 1, 2024 at 7:10 PM
    #36
    TnShooter
    Deogee
    STOCK
    Let's make sure we are dealing with a PCM issue first.
    Go down and unplug the Neutral Safety switch, Check pin 4 (purple wire) for power WHILE CRANKING.
    If no, power. On to the ECM.
    I know this is stupid. As I am 99% sure you'll have no power.
  17. Jun 1, 2024 at 7:11 PM
    #37
    TnShooter
    Deogee
    STOCK
    I have Chilton's..... And it SUCKS.......
    No connector locations and limited pinouts.
  18. Jun 1, 2024 at 7:20 PM
    #38
    TnShooter
    Deogee
    STOCK
    FWIW, this is why I think it's going to be an ECM issue.
    As the ECM sends power to the Neutral switch and the Starter Relay
    I don't mean the ECM is bad. I mean, we likely have an issue to the ECM. (wiring)
    But still do the test I asked in post 36 if you can.
  19. Jun 1, 2024 at 7:24 PM
    #39
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    Are you sure pin 4 is purple and not pink on 4Runner?
    My diagram is showing pink on pin4 of NSS going to E5 pin 8 on ECM.
    Is that right?
  20. Jun 1, 2024 at 7:25 PM
    #40
    TnShooter
    Deogee
    STOCK
