Electrical Gremlin On My Back! HELP!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by J4R, Jun 1, 2024.
  1. Jun 1, 2024 at 9:32 PM
    #61
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Powers:
    E6 Pin 12 (Blue/Yellow) (Crank)
    E8 Pin 1 (Black) (Run) (from EFI Relay (PCM Controlled))
    E8 Pin 2 (Black) (Run) (from EFI Relay (PCM Controlled))
    E8 Pin 3 (Blue) (All Times)
    E8 Pin 7 (Grey) (All Times)
    E8 Pin 9 (Black/Orange) (Run)
    Grounds:
    E4 Pin 6 (Brown)
    E4 Pin 7 (Brown)
    E5 Pin 3 (White/Black)
    E5 Pin 4 (White/Black)
    E5 Pin 6 (White/Black)
    E5 Pin 7 (White/Black)
    E6 Pin 1 (Brown)
    TJTM and TnShooter like this.
  2. Jun 2, 2024 at 2:54 AM
    #62
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    You all are great helping the OP to this extent. This site has some first class people.
    Best of luck to you all.:cheers:
  3. Jun 2, 2024 at 9:54 AM
    #63
    J4R
    J4R [OP] Well-Known Member
    2005 4R 4.0 4X4
    2009 Tacoma motor
    I agree they are awesome and greatly appreciated.
    I just got up fellas going out to check the pink #4 on NSS and EFI 2 fuse now.
    Right?
    TnShooter likes this.
  4. Jun 2, 2024 at 12:16 PM
    #64
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yeah, start there.
    Then move on to the ECM checks Dm93 posted if needed.
    Let us know what you fin on the NSS and EFI No2 fuse.
    TJTM likes this.
  5. Jun 3, 2024 at 12:36 PM
    #65
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    No power on NSS pink #4 wire
    No power on EFI #2 fuse key on
  6. Jun 3, 2024 at 2:00 PM
    #66
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
  7. Jun 3, 2024 at 2:13 PM
    #67
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Do your power and ground checks at the PCM, I don't expect we'll see power on E8 Pins 1 & 2 but we need to see if we have power and ground on the rest.
  8. Jun 3, 2024 at 3:42 PM
    #68
    TnShooter
    Deogee
    STOCK
    As expected.
    The ECM will need to be checked for powers and grounds, as @Dm93 said.
  9. Jun 3, 2024 at 3:44 PM
    #69
    TnShooter
    Deogee
    STOCK
    I'll jump back on in a bit and see how it goes.
    I just hit a poison ivy patch with the weedeater and I got to get home and get washed off.
    Stuff makes me itch.....
    TA-5650 and winkel like this.
  10. Jun 4, 2024 at 1:38 PM
    #70
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    E6 Pin 12 (Blue/Yellow) (Crank) - POWER CONFIRMED
    E8 Pin 1 (Black) (Run) (from EFI Relay (PCM Controlled)) NO POWER
    E8 Pin 2 (Black) (Run) (from EFI Relay (PCM Controlled)) NO POWER
    NO POWER
    POWER CONFIRMED
    POWER CONFIRMED
    @Dm93
    @TnShooter
    Onto grounds right now
  11. Jun 4, 2024 at 1:57 PM
    #71
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    E4 Pin 6 (Brown)
    NO GROUND
    E4 Pin 7 (Brown)
    NO GROUND
    GOOD GROUND
    GOOD GROUND
    GOOD GROUND
    GOOD GROUND
    E6 Pin 1 (Brown)
    NO GROUND
    @Dm93
    @TnShooter
  12. Jun 4, 2024 at 2:05 PM
    #72
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    Ran overlay grounds to known good ground source from where I had no ground
  13. Jun 4, 2024 at 2:10 PM
    #73
    TnShooter
    Deogee
    STOCK
    Lets get those grounds at the ECM fixed.
    E4 - Pins 6 & 7
    Let me see if I can find the ground point location for EE.
    Back in a bit.
    Dm93 likes this.
  14. Jun 4, 2024 at 2:15 PM
    #74
    TnShooter
    Deogee
    STOCK
    Make sure this ground is connected on the engine.Screenshot 2024-06-04 171326.png
    Dm93 likes this.
  15. Jun 4, 2024 at 2:20 PM
    #75
    TnShooter
    Deogee
    STOCK
    For those following along. And what to know why were are checking the EE ground location.
    It's because all the grounds OP is missing on the ECM are tied to the EE ground.
    winkel and Dm93 like this.
  16. Jun 4, 2024 at 2:28 PM
    #76
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    We also need to find connector IC4 and see what's going on with our power there, mabe it's not plugged in all the way or a pin is bent.
    TnShooter[QUOTED] likes this.
  17. Jun 4, 2024 at 2:32 PM
    #77
    TnShooter
    Deogee
    STOCK
    Working on it.....
    Chilton strikes again.
    No connector locations. Just pinouts.
    Might need you for the location.
    Unless I find it before you can get to it.
  18. Jun 4, 2024 at 2:34 PM
    #78
    TnShooter
    Deogee
    STOCK
    I'm kind of hoping that the ground issue fixes the power issue.
    As the ECM is the SUPPLY power. Maybe if we get the ECM online, it will supply power.
  19. Jun 4, 2024 at 2:38 PM
    #79
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It's all in the file I posted in Post #52
    E8 Pin 3 is dead, that power comes from the EFI Fuse (Hot at all times) through Connector IC4 Pin C4 (Blue)
  20. Jun 4, 2024 at 2:50 PM
    #80
    TnShooter
    Deogee
    STOCK
    Good thing you caught that.
    My eyes were seeing it E8- Pin 8...
    And it too goes through IC4.
    It is in fact E8- Pin 3.
    I just need to do better at reading.....:rofl:
    Dm93[QUOTED] likes this.
