Electrical Gremlins
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ThatGuyDave, Jan 2, 2022.
  1. Jan 3, 2022 at 9:16 PM
    ILICKTACOS90
    ILICKTACOS90 Well-Known Member
    The Reverse Engineer
    Middle of nowhere, Montana!
    2019 TRD 6spd; 1984 Hilux; 2002 Cummins
    Custom, only one ever designed and built interiors, heavily welded frame, all sharp metal turned bed rack and a roof top I made for $75. Power pedal, injen intake system, cat delete, summit racing brake proportioning valve controlled on the fly, slightly adjusted or perhaps unrecognizable ECM, built in under bed storage, high clearance rear built with 1/4" on a 6011 1/8" rod at 120 amps, 360 degrees of led light, a PA and CB, on board air, on board propane (to cook food), on board fridge made from an old red bull fridge found on some guys man cave built into the storage cubby under the back seat, imported tranny and clutch from a good friend over in Europe to replace this aisin junk we get, combined 32 gallons fuel capacity, 18 5 gallons of water storage, built in gun locker under RTT, and all it cost was to hear the wife ramble on about upset neighbors at 2 in the morning every night since I bought that damn truck..
    Moral of the story is, back to the basics is never a bad option. I've been gutting my 2019 a little at a time and pin byvlin and wire by wire programming it to my needs, not the designers. In my mind, that means when I botch up and something isn't working, only I'm responsible and can fix it right.
  2. Jan 13, 2023 at 6:11 PM
    miss_fortune13
    miss_fortune13 Well-Known Member
    2016 Tacoma
    Hi! I have the same problem I dealt with last year: driving through super-flooded roads (out of necessity) let water into the BSM right sided harness. I lost power to my heat and fan system as well. My drying and wrapping of the harness lasted for 1 year now it's a problem again.. I took the cap off of the BSM plate and its caked in corrosion. It hasn't worked for years so I don't care about it, but I NEED the fan/heat system. So if i dry off the harness, pack it with die-electric grease and heat shrink it off, my fan/heat should still work?? TIA!
  3. Jan 14, 2023 at 7:55 AM
    Beaner Taco
    Beaner Taco Well-Known Member
    WV
    '17 SR5
    Thanks for comments about a low battery, sounds like it could be my problem.
    I get a check engine code for thermostat and then the trac off light will randomly come on. My mechanic buddy said to clear it and watch the temp gauge and let him know Sunday at church. I haven’t done any electric work and the battery is 5 years old so am optimistic that’s it.
  4. Jan 14, 2023 at 2:30 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    This ^
    Is where I’d be looking into. All the stars align here to find that sob gremlin
    RustyGreen[QUOTED] likes this.
  5. Jan 14, 2023 at 10:54 PM
    SilverlineShockService
    SilverlineShockService Well-Known Member
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    Check you brake light bulbs. Just change them I had my truck go into limp Mode because i had a stupid brake light out and my cluster lit up like a Christmas tree
  6. Jan 14, 2023 at 11:01 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    Is this a 3rd gen "feature" only, or does it also affect 2nd gens / 2.5 gens?
  7. Jan 14, 2023 at 11:13 PM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    Have no idea to honest but all I know
    Is I couldn’t believe a truck would go into limp mode because of a damn light bulb
    ktbell444 likes this.
  8. Jan 16, 2023 at 2:55 PM
    Beaner Taco
    WV
    '17 SR5
    Quick follow-up for anyone who may get the same issue. It was a low battery. I cleared the code (p0128) and found the battery was low. Just not low enough to have any other indication. Charged it and no warning lights after two days. My mechanic buddy said the trac off light will sometimes trip for no other reason than another indicator light.
    GilbertOz likes this.
  9. Jan 16, 2023 at 3:49 PM
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    Is this the OP (original poster) under a different username? Im confused.
  10. Jan 16, 2023 at 4:10 PM
    Beaner Taco
    WV
    '17 SR5
    No, not the OP. I jumped in to thank a couple posters who suggested a low battery as I had my own electric gremlins. It turned out to be my problem.
