Electrical Help
Discussion in 'Lighting' started by Doc V, Feb 15, 2018.
  1. Feb 15, 2018 at 3:25 PM
    Doc V
    Doc V [OP] Well-Known Member
    Caldwell, ID
    2013 Tacoma Double Cab Short Box
    Rear seat 12V Outlets Streamlight Flashlight Install Remote Start Bed lights Amber emergency lighting Aries Grille Guard ARE topper with ski-rack USB power point
    I picked up some lights that have amber and white LEDs in the same housing. I need someone to double check my work on some auxiliary reverse lights/turn signals, before I drop cash on relays, run wires etc. I want to be able to use them two ways:
    1) Slave them to the turn and reverse signals. So they will turn on when in reverse and blink with the turn signals.
    2) Use switch-pros for manual on/off and strobe/flash functionality.
    I appreciate any help you can give me and I will be happy to give you a shout out once I do a write-up.Slide4.jpg
    https://www.amazon.com/gp/product/B06XCWLFHN/
  2. Feb 16, 2018 at 3:20 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    Your diagram looks solid. I don't see an issue jumping out at me. where do you plan to pull the signal for the turn signals?
  3. Feb 16, 2018 at 8:16 PM
    Doc V
    Caldwell, ID
    I’m going to use the front L and R inside the engine bay. I figured it would make it easier to wire and troubleshoot than wiring it in the rear taillight towers. Especially with 3 relays (L/R and reverse). Thanks for your help.
  4. Feb 16, 2018 at 8:59 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    If you have DRL, you may need to get the signal elsewhere. If not, then your golden.
  5. Feb 16, 2018 at 9:02 PM
    Doc V
    Caldwell, ID
    Does DRL effect the turn signals? I was going to use the lateral turn signals on a 2013 (gen2) taco.
  6. Feb 19, 2018 at 10:33 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    Using the side mirror signals will work just fine. DRL only affects the front turn signals.
  7. Feb 19, 2018 at 10:35 PM
    Doc V
    Caldwell, ID
    Good call. I will track those down. I finally got off my lazy butt and stood in front of the truck with the DRL on. All I could think was o_O“wow I am dumb for not realizing the problem with the DRL wire!!” Thank you!
