Electrical help
Discussion in 'Technical Chat' started by Newlife, Jun 3, 2020.
  1. Jun 3, 2020 at 11:57 AM
    Newlife
    Newlife [OP] Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    I am out here now testing.
    engine off fridge running
    Battery 12.5
    First blue sea 10.98-11
    Second blue sea 10.95-10.98
    12v outlet. 10.95
  2. Jun 3, 2020 at 11:59 AM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Battery was purchased Sunday and is a x2 power 27f. 93 ah I believe.
    also fridge is 53 qrt. Book lists it as 55qt
  3. Jun 3, 2020 at 12:03 PM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    the voltage drop for the 10 awg wire is .22 volts. I figured it with 30 feet of wire to be safe, so the wire is not the problem. Check your connections and you will find the problem or like another guy said run a wire straight to the battery
    davidstacoma likes this.
  4. Jun 3, 2020 at 12:07 PM
    Yettee
    Yettee Well-Known Member
    Long Beach, CA
    2019 White Tacoma TRD OR 4x4
  5. Jun 3, 2020 at 12:11 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    no the plug is the “dedicated switch”
    So eliminate the first blue sea and go from battery straight back to the second blue sea? Or are you saying go from battery straight to the 12v. This option I would still need to put at least a 15 amp fuse inline correct ?
  6. Jun 3, 2020 at 12:13 PM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Ok, def not the battery then.
    Over how long of a period of time did it make the voltage drop that low?
    If anything it could just be the fact that the fridge is drawing a lot of current.
  7. Jun 3, 2020 at 12:15 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    It is usually around 20-30 minutes before the fridge will drop into the F1 error and cut the fridge off. And when I check the voltage meter on the fridge it will read low 10’s and sometimes 9.9 the truck will still crank and then the fridge turns back on after having to unplug and replug it back in.
  8. Jun 3, 2020 at 12:22 PM
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    Check the voltage at the plug against the voltage the fridge is seeing.
  9. Jun 3, 2020 at 12:33 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    I’m guessing you mean unplug the plug from the fridge, test the 12v socket and then test the open end of the fridge plug ?
  10. Jun 3, 2020 at 12:38 PM
    Loco_Barbon
    Hugh Mungus
    i LiKe tRuCkS!!
    Back probe the plug so you can see the voltage being displayed on the fridge as well as the voltage on your meter. If the fridge is seeing 10 volts but there is actually 12 volts at the plug, then the fridge is the problem not the power supply.
    davidstacoma and Newlife[OP] like this.
  11. Jun 3, 2020 at 2:42 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    What 12V “Outlet” are you talking about, at the fridge? From your measurements could be a connection problem between battery and first blue sea, not much voltage drop between first blue sea and the second. Have you measured the actual current draw?
  12. Jun 3, 2020 at 2:43 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    The 12v outlet is one I installed in the bed for the fridge to run off of.
  13. Jun 3, 2020 at 2:54 PM
    davidstacoma
    David
    NC
    Since your voltage drop is between your battery and your first blue sea, if I were troubleshooting this I would unhook from the battery and check the resistance across all connections - across the 100A breaker, and across the first blue sea input connector to the 30A output connector looking for a high resistance connection or a bad breaker. Or easier yet just check the voltage to ground at all those connections (input and output connector at breaker, at fuse etc) and see where the voltage drop is.
    And if needed I would measure actual current draw with an ammeter/DMM, and verify the right 12V plug input to the fridge.
    Thatbassguy and SR-71A like this.
  14. Jun 3, 2020 at 3:50 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Trying to get the amperage pull from the fridge now but it’s seeming less than possible with my dmm I’m guessing I’ll have to go buy a better one then the cheap one I have because I can’t get a reading.
  15. Jun 3, 2020 at 4:25 PM
    #35
    davidstacoma
    David
    NC
    Then just do the voltage drop tests I mentioned above and/ or the resistance tests.
  16. Jun 3, 2020 at 7:42 PM
    #36
    Loco_Barbon
    Hugh Mungus
    i LiKe tRuCkS!!
    I missed this post. Others are correct, the voltage drop is between the battery and first fuse box. Start at the battery terminals and work you way to the box checking voltage at each connection.
  17. Jun 3, 2020 at 8:18 PM
    #37
    6 gearT444E
    Deep South
    Herculiner Hootus
    You need a quality meter, not a cheap HF one. Here's my go to meter for troubleshooting, does clamp on AC and DC amps. It sounds like you have a bad connection between your battery and the first blue sea, losing 1.5 volts is pretty significant. You either have a loose/bad connection or a poor ground somewhere.
    EdgemanVA and Thatbassguy like this.
  18. Jun 4, 2020 at 4:58 AM
    #38
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Seems like most people missed this ^ post for some reason. The issue is between the battery and the 1st blue sea. That's a pretty decent voltage drop right there from 12.5 to 10.98. Look at everything between those two points.
    Theres no need for a fancy meter in this case. If he wants to be meticulous about it, he can just measure the resistance of the dead circuit between each connection before the 1st blue sea. Personally I bet a visual inspection will show the problem.
  19. Jun 4, 2020 at 5:04 AM
    #39
    6 gearT444E
    Deep South
    Herculiner Hootus
    I didn't say there was, the 325 is not a fancy meter by any sorts. It does provide the ability to measure the current without disturbing connections which can help to pinpoint where the issue might be. From the readings provided, there will be a loose/corroded connection between the battery and first fuse block.
  20. Jun 4, 2020 at 9:47 AM
    #40
    davidstacoma
    David
    NC
    That’s a nice meter. I use flukes a work sometimes but at home I have an inexpensive but quite accurate (per the specs) DMM from China. :p
    SR-71A likes this.
