Electrical Issue 2001 Toyota Tacoma 6cyl 4WD
Discussion in '1st Gen. Tacomas (1995-2004)' started by Swivot, Apr 24, 2017.
  1. Apr 24, 2017 at 3:40 PM
    Swivot
    Swivot [OP] Well-Known Member
    I hit a bump offroading and suddenly my stereo will not turn on, my dome lights have no power and my interior clock has no power. Also when i remove the key from the ignition I have no power on the door locks and window locks. They car starts and drives fine and as far as I can till the battery terminals seem to be ok. I took it to an electrician specialist and he said it could be a ground, blown fuse, or wiring problem internally. He wants $85 to find the issue and if its an easy one fix it. I want to see if i can poke out the issue myself so has anyone had these symptons before and or know what the problem is? Is it as simple as tweaking with a few wires or fuses or should i invest them money to have a proffesional fix it?
  2. Apr 24, 2017 at 3:42 PM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    He told you all the things to check there's no magic cure things bump lose... it could be any of them check your fuse box that's the easiest part.
    Swivot[OP] likes this.
  3. Apr 25, 2017 at 6:10 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Windows wont have power when you remove the key
    Check plugs on front and back of integration module. Also check fuses and relays outside.
    wilcam47 likes this.
