Electrical Issue after LED interior light change?
Discussion in 'Lighting' started by KyJay2019, Jun 16, 2023.
  1. Jun 16, 2023 at 7:43 AM
    KyJay2019
    KyJay2019 [OP] New Member
    2019 Metalic Gray Tacoma
    Hey!
    So yesterday I was changing my interior lights (Dome, vanity, and map lights) to LED (lights are from Amazon). They all worked perfectly fine for a hot minute and now they dont work. I've changed them back to the standard OEM lights but still nothing. I checked all my fuses and wires but they look to be fine. Any suggestions? Should I just change the fuse anyway? Starting to panic, any and all advice is appreciate! Thanks
  2. Jun 18, 2023 at 8:23 AM
    Qbrute
    Qbrute Well-Known Member
    Ontario, Canada
    2023 Black Tacoma OR SB
    yikes. I was just thinking I should do this, I already have the new LEDs. did you follow a specific method or tutorial?
    KyJay2019[OP] likes this.
  3. Jun 18, 2023 at 8:34 AM
    KyJay2019
    Be very careful, turned out I blew a fuse that I totally missed upon my inital check.
    Qbrute likes this.
  4. Jun 18, 2023 at 8:36 AM
    Qbrute
    Ontario, Canada
    Thanks, will do!
  5. Jun 18, 2023 at 8:45 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    The best way I've found to do the dome lights is to pull down the entire console and remove the bulb via the removable socket, rather than just removing the clear cover and removing it that way. I never ran into any fuse issues and this could be part of why. Also, make sure your lights aren't on when changing the bulb. Sounds simple but some people would have it on to ensure seeing the polarity is correct before finishing the job just to save a few seconds.
