Electrical issues 2023 Tacoma TRD Sport Manual
Discussion in 'Technical Chat' started by holobow, Aug 9, 2023.
  1. Aug 9, 2023 at 2:17 PM
    holobow
    holobow [OP] Member
    Hi all really need some help here,
    I purchased a brand new 2023 Tacoma on June 28, 2023.
    Traded in my 2018 Tacoma TRD Sport Manual.
    I swapped my K&N cold air intake, tonneau cover and aftermarket TRD pro grill with 4 LED lights.
    --The Lights are connected to the fuse box with an add a fuse along with the ground attached to the truck under the bolt on the left side of vehicle.
    I am now having electrical issues a month later the reinstallation of TRD grill and lights.
    Truck started with 25km and now has 5000K (Drive a lot for work)
    Electrical issues are unable to be diagnosed by dealer after a preliminary inspection.
    --Issues include:
    1. First day I noticed (August 6th.), in the morning coming out to my truck, open the door and the ventilation system has been running all night, light is still on for the air on the center panel.
    --Played a round of golf. Came out to the truck and it was off back to normal. park the truck at home that night
    2. Second day, (August 7th) come out in the morning, my brake lights are on, headlights on and the ventilation system is once again on with display still on.
    Dealer cannot guarantee that the addition of the add a fuse did not send a back signal and mess up the computer system. This means they could stick me with the bill and this wouldn't be under warranty.
    On their preliminary inspection the truck thinks the key is still in the ignition when there is no key. They also removed the steering panel and there are no wires that have been manipulated.
    I currently am absolutely pissed off that a brand new truck is having electrical issues. My 2018 had the exact same set up for over 2 years and I never experienced any issues.
    If any of you have any guidance or resolutions for me it would be greatly appreciated.
    Thanks...
  2. Aug 9, 2023 at 2:22 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Well...since they know theres been electrical work done,your at there mercy now..
  3. Aug 9, 2023 at 2:22 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    How about undoing your mods and seeing if the truck goes back to normal? Seems premature to blame the truck yet.
    what fuse did the add a fuse connect to?
    21TacoTRDPRO and TnShooter like this.
  4. Aug 9, 2023 at 2:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If they can’t “guarantee” that the add-a-fuse caused the problem.
    Then they need to fix the problem.
    BTW, what fuse did you tap?
  5. Aug 9, 2023 at 2:33 PM
    holobow
    holobow [OP] Member
    No kidding. I am going to return to OEM and try another dealer.
    HondaGM[QUOTED] likes this.
  6. Aug 9, 2023 at 2:38 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Did they make a repair order?...I dont know about Toyota,but Honda has all there dealers tied together..so when a car is wrote up at another dealer they can see every RO that has been done on that vehicle,and where it was done...all comments etc.
  7. Aug 9, 2023 at 2:43 PM
    holobow
    holobow [OP] Member
  8. Aug 9, 2023 at 2:43 PM
    holobow
    holobow [OP] Member
    Truck is back to OEM and I am still having the same issue.
  9. Aug 9, 2023 at 2:45 PM
    holobow
    holobow [OP] Member
