Electrical issues dash, FIXED
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Feb 28, 2020.
  1. Feb 28, 2020 at 7:30 AM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    Anyone,
    Im having random electrical power loss.
    The dash lights, radio, heater, alarm, clock all loss power while driving for
    2 to 5 seconds and then power comes back.
    Dosen't effect the motor.
    What could this be?
  2. Feb 28, 2020 at 7:33 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    does the new alternator have anything to do with it? :notsure:
  3. Feb 28, 2020 at 7:37 AM
    1997tacomav6
    Denver
    No, don't think so, maybe a ground issue?
    Wyoming09 and GQ7227[QUOTED] like this.
  4. Feb 28, 2020 at 8:26 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    maybe this
    :alien: :alien: :alien: :alien: :alien: :alien: :alien:
    they want everybodys tacomas
    1997tacomav6[OP] likes this.
  5. Feb 28, 2020 at 8:39 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    :rofl::rofl:
    But uselessly misinformed:D
    Poll says
    Bad ground:thumbsup:
    Wyoming09 likes this.
  6. Feb 28, 2020 at 1:29 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    This is going to be interesting as those loads are grounded through several different ground points.
    Be simple if it was all one ground a Major ground loss would take out the ECM
    Loose fuses ??
    You say Alarm I would look real close at that No telling just what it is tied into .
  7. Feb 28, 2020 at 3:13 PM
    1997tacomav6
    Denver
    It was the neg battery cable to the battery post.
    The clamp is as tight as it will go and its still loose,
    Shim time :)
  8. Feb 28, 2020 at 3:16 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The fact the ECM did not stumble is interesting.
    Then you might not have noticed .
  9. Feb 28, 2020 at 3:17 PM
    1997tacomav6
    Denver
    Now that I think about I think it did a few times, but I thought it was something else
  10. Feb 28, 2020 at 3:18 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Wulf and 1997tacomav6[OP] like this.
  11. Feb 28, 2020 at 3:18 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    glad it was a easy fix
  12. Feb 28, 2020 at 3:22 PM
    Wulf
    rock raisin
  13. Feb 28, 2020 at 3:24 PM
    0xDEADBEEF
    I was really happy when I figured it out.
    Minor pothole: I'm not sure the diameter of that hole, but it matched up with the clamps I had laying around already. Not sure if the ones I linked on Amazon are the same.
  14. Feb 28, 2020 at 3:26 PM
    Wulf
    rock raisin
    I have had a set of military style terminals that have gone uninstalled for over a year because I've thought I would have to make custom cables and dreading it :homer:
  15. Feb 28, 2020 at 3:28 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    I had no idea they made those!!! I cut mine off abd put some cheesy aftermarket clamp on there. DAMN
  16. Feb 28, 2020 at 3:28 PM
    1997tacomav6
    Denver
    Good call, change of plans to this
  17. Feb 28, 2020 at 4:57 PM
    1997tacomav6
    Denver
    All better, I trimmed the OEM cable so that there was just the tab and drilled the wire tab holes out a bit and both OEM cables fit on the wing bolt section now.
    Black DOG Lila and 0xDEADBEEF like this.
  18. Feb 29, 2020 at 1:43 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I use these clamps on all my vehicles.
    So much better
