Electrical issues in an '06 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Secondarychaos, Mar 28, 2011.
  1. Mar 28, 2011 at 8:36 PM
    Secondarychaos
    Secondarychaos [OP] Member
    Dan
    Grass valley california
    '06 TRD tacoma
    Hello,
    My cousin is having some problems with his 2006 Tacoma TRD Access Cab Manual. It started with the dome light ,then the compass, reverse lights , blinkers and finally the speedometer. all of these have gone out in the last week or so . He and I found a towing light controller that his friend put on when he borrowed the truck, which burnt two fuses while burning itself .
    I have since pulled the controller and insulated the leads, as well as replaced the fuses, but those things are still not working. Chassis ground appears to be fine and the blinker lights work fine if used in the emergency flashing mode . The only DTC's are for Emissions and a speedometer malfunction . Ive been searching the web for almost a week, with no success so any help would be greatly appreciated.
    Thanks,
    Dan
  2. Mar 29, 2011 at 5:16 AM
    98tacoma27
    Ben
    Not Beech Creek
    I'd suggest checking the ECU-B fuse if you haven't already. It might be a good idea to check them all; under the hood and in the cab.
  3. Mar 29, 2011 at 8:49 AM
    Secondarychaos
    Dan
    '06 TRD tacoma
    Thanks for the link.
    We went through every fuse and relay, it was only the two fuses related to towing that were out.
  4. Mar 29, 2011 at 9:12 AM
    98tacoma27
    Ben
    Not Beech Creek
    Do you remember what the code was for the gauge cluster?
  5. Mar 29, 2011 at 12:28 PM
    Secondarychaos
    Dan
    '06 TRD tacoma
    P0500 was the speedometer one,
    the emissions were p0441, p0455, p0456
    To the second poster there, you sound awfully sure that's what went out. I'm guessing you're speaking from experience?
    Thanks again for the help guys.
  6. Mar 29, 2011 at 12:30 PM
    Secondarychaos
    Dan
    '06 TRD tacoma
    When you say combination meter, does that include the tachometer?
  7. Mar 29, 2011 at 12:54 PM
    98tacoma27
    Ben
    Not Beech Creek
    Combination meter AKA gauge cluster. If just the speedo went out yet all of the other lights are functional, then that is a good indication the entire cluster is FUBAR. That will cause the 500. It sounds like you have a nasty short some where.
    441
    455,456,500
  8. Mar 29, 2011 at 5:19 PM
    Secondarychaos
    Dan
    '06 TRD tacoma
