Electrical issues; key fob, traction control, airbag light, emergency brake light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Li0nel1234, Mar 19, 2014.
  1. Mar 19, 2014 at 6:42 PM
    Li0nel1234
    Li0nel1234 [OP] Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    Has anyone else run into this issue?
    A few days ago my emergency brake light would come on after I drove my truck a few feet.
    - I've read this could be something about the cable slack
    I went weeling this weekend but today all of a sudden my key fob will not unlock or lock or get my truck to even beep. Neither fob will work.
    My passenger airbag warning light on the center dash is blinking and in my dash the airbag light and the traction control light is on.
    Is this because something got wet? We had some snow on Tuesday but nothing much...
    Should I take it into Toyota?
  2. Mar 19, 2014 at 6:46 PM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    Day after I bought my truck, check engine light and trac off light came on. When I put the truck in Drive, the D and the 2L would both light up.
    I had a bad ECM. Not sure what your issue is, to be honest... but I know a bad ECM makes the lights do silly shit. Everything else worked as advertised.
  3. Mar 19, 2014 at 6:46 PM
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    I had similar issues. Mine was a blown fuse. One of the ignition fuses i believe. I would start pulling your interior box fuses and see if maybe one is blown.
  4. Mar 19, 2014 at 6:58 PM
    Li0nel1234
    Lionel
    Denver
    14 TRD OR DCSB SSM
    Ok I'll check the fuses in the AM. Thanks!
    Would an autozone type store have a sensor that could tell what's wrong?
  5. Mar 19, 2014 at 7:01 PM
    kenneth.morris07
    Kenneth
    College Station, TX
    08 PreRunner
    No. I took mine to them to see if it showed any codes, but it didn't.
  6. Mar 19, 2014 at 7:03 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Take it to the dealer, your warranty will cover it if you didn't screw it up.
  7. Mar 19, 2014 at 7:07 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If it was me, I would take the brand new truck in, but for God's sake don't tell them you were wheeling. Warrenty coverage can be denighed for abuse of vehicle.
    I'm betting you have a bad wheel speed sensor or cable. Could just be dirty and a good cleaning may help.
  8. Mar 19, 2014 at 7:43 PM
    Li0nel1234
    Lionel
    Denver
    14 TRD OR DCSB SSM
    I just washed/detailed it. So we'll see... Also did it so if I took it in they wouldn't know it was from wheelin'
    I'm crossing my fingers that its fine in the morning.
  9. Mar 20, 2014 at 7:31 PM
    Li0nel1234
    Lionel
    Denver
    14 TRD OR DCSB SSM
    Ok, I found the issue.I checked the fuses and they were all good except one and a plug was loose. Not sure how that happened... but all is well now not sure if it was a combo of both or what. Thanks everyone for your inputs.
  10. Mar 20, 2014 at 7:40 PM
    kenneth.morris07
    Kenneth
    College Station, TX
    08 PreRunner
    I had a feeling that's what the problem was. Glad it got sorted out!
  11. Mar 20, 2014 at 7:50 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    But Toyota advertises it as an Offroad truck... :rolleyes:
  12. Mar 20, 2014 at 7:54 PM
    OffroadToy
    fuse number and location?
    Brian007Taco likes this.
  13. Jul 21, 2020 at 3:29 PM
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    OP, do you remember what fuse and location?
