electrical issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by 96TRDsoup, Apr 28, 2017.
  1. Apr 28, 2017 at 9:08 AM
    96TRDsoup
    96TRDsoup [OP] New Member
    Tylan
    96 tacoma 3.4L supercharged
    so, started happening last week. Every time I have my headlights on and I turn my blinkers on, all the lights shut off. Anyone know why they would do that?
  2. Apr 28, 2017 at 9:11 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Sounds like you have a short somewhere? Maybe something going on with the stalk on the steering column.
  3. Apr 28, 2017 at 10:47 AM
    96TRDsoup
    Tylan
    Would it be cheaper for me to replace the wiring harness in there or take it to a shop?
  4. Apr 28, 2017 at 10:52 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    depends could be a relay
  5. Apr 28, 2017 at 11:25 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Sounds like the problem is in the turn signal / headlight switch stalk.
  6. Apr 28, 2017 at 12:00 PM
    96TRDsoup
    Tylan
    have you ever replaced a stalk, and if so, how difficult is it? Im not too fond of solving electrical issues
  7. Apr 28, 2017 at 12:09 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Replacing the stalk is pretty simple. Unhook the battery (working near airbag connections. the yellow ones) Remove the knee bolster and covers around steering column. There is 2 screws behind steering wheel that you can access by turning the wheel 90 degrees. Should have a few screws that holds the whole switch on and some electrical plugs to unhook.
  8. Apr 28, 2017 at 12:13 PM
    Glamisman
    Glamisman Well-Known Member
    damn tough to diagnose electric over the internet... there is a integrated relay panel just above your left foot when driving and almost everything seems to go through it. Without a diagram, a tester and paitence you are just fumbling around and getting frustrated.
    Brie likes this.
  9. Apr 28, 2017 at 12:41 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    When you're not moving with lights on start jiggling the column around. I also bet it's in the stalk. Probably a wire rubbed loose or a contact somewhere. Once you take the covers off it's fairly simple to see what's going on. Just go for it!
    mechanicjon likes this.
