Electrical issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yotadawg22, Mar 25, 2023.
  1. Mar 25, 2023 at 2:27 PM
    Yotadawg22
    Yotadawg22 [OP] Member
    2005 Tacoma SR5 4x4, V6
    3.5 inch rough country lift
    Hello, bought a 2005 base model 4wd recently, V6 as a hunting truck. Runs great, engine and transmission very smooth. Have several issues with instrument panel I’ve been working on. Speedometer and odometer don’t work, and gas gauge will go to full but never drops below 3/4 even when empty. ABS, check engine, and parking break light always on. Had instrument cluster tested and no issues with it, replaced transmission speed sensor and all four wheel speed sensors with no luck. Dropped fuel tank and tested the fuel sender, resistance tests out and is working well. Tested a new fuel sending unit and fuel gauge still won’t correct. Does this sounds like a ECM issue. I’m no mechanic, just YouTube trained. Thanks for advice
  2. Mar 25, 2023 at 2:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    While we wait for @TnShooter and @Dm93 and @Bishop84 to show up let me ask if there are any codes you have pulled? And if the brake master is full of fluid and the e brake is fully released.
  3. Mar 25, 2023 at 3:02 PM
    Bishop84
    Bishop84 Well-Known Member
    HondaGM, TnShooter and Dm93 like this.
  4. Mar 25, 2023 at 3:04 PM
    Yotadawg22
    99% sure the only code that showed was P0500, the brake fluid is full and parking brake release
  5. Mar 25, 2023 at 3:19 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What codes
    What code(s) are in the ABS module? You need to address any codes related to the rear wheel speed sensors before proceeding with diagnosing the P0500 code.
    HondaGM, Jimmyh and TnShooter like this.
  6. Mar 28, 2023 at 6:35 PM
    Clearwater Bill
    Billy
    Largo Florida
    And here ladies and gentlemen we have another example of unfinished business.
    Dm93 likes this.
  7. Mar 28, 2023 at 6:49 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That seems to be the case with nearly half the threads these days.
    Question is asked, some answers are given, OP may make a couple replies then never returns.
  8. Mar 28, 2023 at 6:52 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Cats ate his face.
    HondaGM likes this.
  9. Mar 28, 2023 at 6:58 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    That sux
    Rock Lobster[QUOTED] likes this.
  10. Mar 28, 2023 at 6:58 PM
    Yotadawg22
    This truck is a side project, been super busy at work and haven’t had a chance to figure out the ABS codes yet, I appreciate you guys help. Hope I can get around to it in the next couple days.
    TnShooter, Clearwater Bill and Dm93 like this.
  11. Mar 28, 2023 at 7:01 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No worries, everyone just figured you weren't coming back since you hadn't responded for a few days.
  12. Apr 2, 2023 at 11:40 AM
    Yotadawg22
    I finally got around to looking, I got ABS code 32 when I manually tested
  13. Apr 2, 2023 at 12:29 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's for the left front speed sensor, that shouldn't cause it to stop reporting vehicle speed to the cluster unless there is another issue.
  14. Apr 2, 2023 at 1:19 PM
    Yotadawg22
    That’s what I thought, I’m just stumped as to what to check next
  15. Apr 2, 2023 at 1:45 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
