Electrical issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jonylawless, Jun 29, 2024.
  1. Jun 29, 2024 at 5:43 PM
    jonylawless
    jonylawless [OP] Member
    johnathan
    2012 TRD sport 4x4
    I have a 2015 trd sport I changed the clutch on ac compressor.then the altenator now the abs brake light on along with check engine light.windows won't roll up or down cruise won't work.the ac /heater blower won't work.headlights won't turn off with key.the lighter use plug doesnt work.speedo doesn't work .I've checked fuses and relays.anyone ever have this issues or have an idea.im thinking a ground .thank you for any advice.
  2. Jun 29, 2024 at 5:49 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Check the 10A IG1 No.2 fuse.
    But, I have a question.
    How are you turning you headlights off now?
    Or are they staying on all the time. Key off and out?
    Dm93 likes this.
  3. Jun 29, 2024 at 5:53 PM
    TnShooter
    Deogee
    STOCK
    Might as well check the 7.5A ECU-B fuse too.
  4. Jun 29, 2024 at 5:55 PM
    jonylawless
    johnathan
    2012 TRD sport 4x4
    I turn them off manually before the headlight would tur.n off with key
  5. Jun 29, 2024 at 5:56 PM
    jonylawless
    johnathan
    2012 TRD sport 4x4
    They stay on when key is off
  6. Jun 29, 2024 at 6:12 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    +1 I bet the IG1 No 2 fuse is blown, it's in the interior fuse box behind the tray left of the steering column.
    TnShooter[QUOTED] likes this.
  7. Jun 29, 2024 at 6:14 PM
    jonylawless
    johnathan
    2012 TRD sport 4x4
    Thanks ilk check again
    TnShooter likes this.
  8. Jul 3, 2024 at 7:34 PM
    jonylawless
    johnathan
    2012 TRD sport 4x4
  9. Jul 3, 2024 at 7:36 PM
    jonylawless
    johnathan
    2012 TRD sport 4x4
    Thanks TNShooter you were right I appreciate it.
