electrical mess
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BooceTheTaco, Dec 13, 2020.
  1. Sep 9, 2025 at 6:27 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Did you fix this?
  2. Sep 12, 2025 at 1:58 PM
    TimothyW
    TimothyW New Member
    Tuesday
    Tim
    i got a junction box, and it isnt that. identifix is bent on U0140 being the BCM. io also note my driver window always works. ignition off and just the driver window from the master switch. odd.erasing the BCM codes i get B1244 light sensor circuit.
  3. Sep 12, 2025 at 2:08 PM
    Palomar Taco
    Palomar Taco Well-Known Member
    Aaron
    So FL
    '23 Taco SR5 2wd Street Truck
    Sounds like a short within a harness somewhere at this point. Good luck
  4. Sep 13, 2025 at 12:44 PM
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    Sometimes when I look for impossible shorts that keep nuking fuses I just remove the fuse and put a small incandescent bulb in its place. Use something that’s low draw so it doesn’t get super hot and melt onto anything it’s touching. It’ll require a little bit of DIYing, I typically solder some wires onto the bulb and also add some solder to the stripped ends of the wires so they are stiff and can’t have little strands sticking out. Then I start unplugging things or wiggling wires until the light turns off or flickers. The other thing you can do while the bulb is illuminated is use an inductive clamp to try and find what circuit/wire the current flow goes down and trace that wire out.
