electrical pblms?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mistery, Jan 28, 2020.
  1. Jan 28, 2020 at 6:37 AM
    mistery
    mistery [OP] Member
    I have a 1998 Tacoma, automatic, 6cyl. 4x4. crazy thing sometimes curise works , most of the time it does't, on/off switch has no effect, when it decides to work the green ON light illuminates otherwise it stys off, also airbag light faintly stays on even when motor is off and key is removed, my truck has built in clock when it decides to work it loses pwr when I attempt to set the time. this is somewhat aggravating! ant ideas?
    Taco critter likes this.
  2. Jan 28, 2020 at 6:52 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard
  3. Jan 28, 2020 at 6:54 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Check all of your ground straps. One beside the battery to fender. One from rear passenger cylinder head to firewall. Big main one from lower block to battery. One big cluster that attaches to the intake manifold driver side.
    TWJLee and Taco critter like this.
  4. Jan 28, 2020 at 9:36 PM
    Glamisman
    Glamisman Well-Known Member
    the most common issue is a mis-adjusted brake light switch.
  5. Jan 28, 2020 at 9:38 PM
    Bishop84
    Bishop84 Well-Known Member
    This is a spiral cable issue, very common with Tacoma.
    All advise mentioned is helpful, but if you search for spiral cable on here you'll find this correlates with your problem.
    Scan the SRS code and you'll see its like B1801 or something close to that.
    The spiral cable or clockspring is what connects the steering wheel controls, horn, and air bag to the vehicle, it wears over time.
    I bet your horn doesnt work well either.
    tacoma_ca likes this.
  6. Jan 28, 2020 at 9:39 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Oh, do tell?
  7. Jan 29, 2020 at 7:24 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    The only year I can say this about for sure is 1995. I have one that the clock spring seems to be faulty, but everything on the column except the horn still works. It is a 3.4L auto 4x4, has cruise, and it works flawlessly.
    I could be wrong because I have not tested the clock spring myself, but, when I bought this truck it had been wrecked. The truck had been in a strong left front collision and the A/B did not deploy. The PO had already installed a small horn switch on the bottom of the steering column. He may have not known the A/B was disabled. I bought it from salvage yard, so I never got to talk to him.
