Electrical problem, plz help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Alderleet, Feb 19, 2012.
  1. Feb 19, 2012 at 9:52 PM
    Alderleet
    Alderleet [OP] Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Hey all, I have a bizarre electrical problem.
    I drove my truck to my girls house, and turned it off. When I tried to start it, it had all the lights on. I turned it to the starting position, and it went black. All lights and electrical systems shut off. Cabin lights, headlights, everything.
    I tried again a couple hours later, and opened the engine fuse box and the cabin fuse box. No bad fuses there.
    The battery cables are fine too.
    However, after peeking inside the fuse boxes, I noticed the system came back on, and it started.
    What the fuck... This is baffling.
  2. Feb 20, 2012 at 2:21 PM
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Huzzah mystery solved.
    Turns out, when firestone worked on changing all my fluids, they pulled the negative terminal clamp off, and did a piss poor job tightening it back on.
    Last night, in 10* weather, using my iphones flashlight, it looked like it was tight on. Sure enough this morning, i went and wiggled it around and saw it had a gap.
    I scrubbed, reapplied electric grease, and tightened it back on.
    I feel retarded right now, it looked fine last night
  3. Feb 20, 2012 at 2:28 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I love finding solutions to problems like that. So much cheaper :D Glad you figured it out :cheers:
