electrical problem(s)
Discussion in '1st Gen. Tacomas (1995-2004)' started by broken taco, Dec 30, 2011.
  1. Dec 30, 2011 at 6:55 PM
    broken taco
    broken taco [OP] Well-Known Member
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    Trail gear 3 Link Solid Axle Swap kit, 14 " Fox coil overs with reservoirs up front, Chevy 63 leaf spring swap with ruff stuffs Chevy 63 swap kit, 14 "Fox shocks on the rear, 37" tires, Custom front bumper by Next Venture Motor Sports with a warn winch, glassworks unlimited fender flares, custom rock rails with kickups (modeled after Relentless Fab Rock sliders), rear bumper from streetacos.com (with custom rap around protection for fiberglass fenders and the hitch receiver hidden behind the license plate that is on hinges), HID off road lights on front bumper, rigid pods on rear bumper with red back lighting, high lift mounted in the bed, onboard air, Flowmaster muffler, aftermarket air intake, alarm system, Alpine Deck, Alpine amp, Alpine speakers, JL W6 12" subwoofer, JL amp.
    i went to my friends house out and the desert and drove my truck. i didn't jump it and i feel like i didnt push it too hard. (i was up there for 3 days with alot of driving) (and i have taken my truck out offroading alot before )
    i had electrical problems. (fixed them finally)
    My radio doesnt works. It shut down when i was driving on a flat part of the road. i didnt hit like a huge bump or dip when it turned off.
    The dome light wont turn on and the bulb is still good.
    When i hit the lock button on my key my truck beeps and flashes the parking lights like it used to but my doors dont lock anymore. The alarm still goes off though.
    the odometer resets trip A and B everytime i turn my car off.
    WOW I FEEL STUPID. I THOUGHT I CHECKED ALL THE FUSES..... BUT I DIDNT. I RECHECKED THEM LIKE hayabusa3303 SAID AND THE DOME LIGHT FUSE WAS BLOWN. I FIXED IT AND EVERYTHING WORKED AGAIN. THAT IS UNTIL I HIT A BUMP AND IT BLEW AGAIN. NOW EVERY TIME I PUT A FUSE IN IT BLOWS EVEN IF THE CAR IS OFF. AND IF IT DOESNT BLOW IMMEDIATLY, IT WILL WHEN I HIT A BUMP IN THE ROAD. IM GUESING THAT MEANS THERES A WIRE LOOSE SOMEWHERE. WHAT DO YOU THINK
    I will try to put up some pictures later once i get them from my friend. i think the only pictures are of when i got stuck going up a huge gravel hill.
    I also ripped off and cracked my underglow which i dont really care about. and i was backing up down a skinny canyon thing because it ended and i couldn't turn around and turned to much and scraped the powder coating or my front bumper.
  2. Dec 30, 2011 at 7:06 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Sounds like there's a ground somewhere. These can be a pita to find. It can be pretty much anything, anywhere. Look for degraded, melted, stripped wires (in an 2002, most of your wires will look shitty). Start off with after market installations such as alarm systems, lights, etc... Also check your battery charge. If there's a ground it will drain the battery.
    Good luck!
  3. Dec 30, 2011 at 7:20 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    recheck all your fuses under the hood also.
    With radio out and your trip dash acting screwy sounds like you have a fuse out.
  4. Dec 30, 2011 at 10:59 PM
    broken taco
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    Thanks. hopefully i will find it. and hopefully i will find it quickly.
  5. Dec 30, 2011 at 11:01 PM
    broken taco
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    i checked the fuses under the hood but i will check them again. hopefully its just a fuse but i bet it will be a ground like StAndrew said.
  6. Dec 30, 2011 at 11:07 PM
    broken taco
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    i got stuck in a huge gravel pit. i was acouple feet from the top but didnt make it. then i went to back down like i have done before but my truck wanted to turn and i was crawling down slow enough where i wouldn't tip if i turned so i let my truck turn and i didnt see the little drop off. oops :eek:
