electrical probles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prerunner taco, Apr 15, 2009.
  1. Apr 15, 2009 at 2:23 PM
    prerunner taco
    prerunner taco [OP] New Member
    washington state
    07 prerunner
    anyone got suggestions?
    2006 prerunner with tow package automatic
    turnsignals, daytime running lights, backup lights and shiftselector on dash do not work. also have to use shift lockout to shift:confused:
  2. Apr 15, 2009 at 2:24 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    Might be a short with the electrical wiring, not sure how much the fix costs but i wouldnt buy it.
  3. Apr 15, 2009 at 2:25 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    fuse?
    Have you done any wiring lately on the truck?
  4. Apr 15, 2009 at 2:41 PM
    TEX357
    TEX357 TX
    05 TACOMA
    Welcome BTW!:wave:
  5. Apr 15, 2009 at 4:31 PM
    prerunner taco
    washington state
    07 prerunner
    I tried hooking up a backup camera. I have had a kenwood 7" dvd in the dash for about a year with no rearview camera. The deck calls for a wire to be tied into the backup lights. I ran the wire back to where the tow package is at the 7way trailer harness. no shorts in the wire. before I ran the wire I looked behind the glove box for the same color wire that i found in the 7way harness. when I hooked up a voltmeter to similar colored wires at the harness behind the glove box, I heard a tick sound come from the drivers side underdash. However, I don't see any relays or fuses on that side.
  6. Apr 15, 2009 at 6:49 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    if you open that little coin holder or whatever you want to call it on the left side of the steering wheel. You can pull that thing out and you should see the fuse box.
  7. Apr 15, 2009 at 6:55 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    definately a fuse. do like ^^ said and check the fuses in that box
  8. Apr 15, 2009 at 7:43 PM
    prerunner taco
    washington state
    07 prerunner
    I'm a retard. never knew there was a fuse panel there. ign 1 was blown. THANK YOU ALL. very good forums.:)
