Electrical question, do I need a circuit breaker?
Discussion in 'Lighting' started by Redgrom, Jan 20, 2012.
  1. Jan 20, 2012 at 12:10 PM
    Redgrom
    Redgrom [OP] http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Hello, considering adding a few additional lights (led bar, back up lights, and bed lights, already have PIAA 520's) I am going to add a blue sea fuse box but after searching around most seem to add a circuit breaker. I will admit I don't understand why you need to add a breaker if you already have fuses. The limited info I found said to get a 100 amp breaker. Can someone please enlighten me.
    Thanks!
  2. Jan 20, 2012 at 12:18 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I would guess so you could shut off the added fuse panel completely if you ever wanted to? :notsure:
    So far I've got 520's and 540's run off the main fuse panel using in-line fuses. I wouldn't hesitate to add another pair of lights without a fuse box or ciruit breaker. I can't imagine the LED's would have a whole lot of draw so I'd go with not required for that kind of loading. If you have a winch, 8 lights across the front, bed lights and an LED bar on the roof that might be another case.
  3. Jan 20, 2012 at 1:06 PM
    Redgrom
    Brent
    san clemente
    Thanks, so besides being able to isolate the add-on's what purpose does it serve? It's only another $45 ish but if I don't need to.
  4. Jan 20, 2012 at 1:15 PM
    Pugga
    Massachusetts
    I'd PM one of the other members you saw running a circuit breaker and ask why. For your use, that doesn't seem like an excessive amount of added draw so I can't see a need for the circuit breaker. I've got (and been operating for a couple years) almost as much draw as you will have and don't even have the added fuse panel.
  5. Jan 20, 2012 at 1:26 PM
    Redgrom
    Brent
    san clemente
    Thanks Mike! The only reason i'm thinking of adding fuse panel in to keep it organized.
  6. Jan 20, 2012 at 1:30 PM
    Pugga
    Massachusetts
    If could start over again, I'd add the fuse panel like you're doing. I just kept adding things one at a time and now I have an organized rat's nest of wiring in the under hood fuse box. I only planned to have 1 pair of lights, then I found TW, I now have 3 pairs of lights... :cool:
  7. Jan 20, 2012 at 9:15 PM
    joes06tacoma
    Joe
    Central Coast, CA
    A fuse or breaker is there to protect the wiring or components that are down stream of the fuse or breaker. If the fuse block is rated at a max of 100amps then it could make sense to install a breaker before the fuse block. On the other hand, if all the fuses downstream of the block add up to less than the fuse block is rated for, then it's not needed.
    I've done aux fuse blocks before. I don't use a breaker. Here's why: I don't add more amp draw than the block is rated for, and there is usually nowhere to mount the breaker right at the battery. There is a length of cable from the battery to the breaker. With or without the breaker, there will be an unfused cable, unless you can mount the breaker ON the battery.
    Does that make sense?
    You also have an unfused length of battery cable from the battery to the starter. As long as you protect the cable running to the fuse block from damage and secure it well, there is no difference between the two. On the other hand, if you mount a breaker on the fender and run a battery cable from the battery to your breaker and you do a poor job of it, if the cable shorts out before the breaker, you have a serious problem.
