Electrical question for truck caps
Discussion in 'Tonneau Covers, Caps and Shells' started by ATR55, Nov 9, 2016.
  1. Nov 9, 2016 at 1:21 PM
    ATR55
    ATR55 [OP] Well-Known Member
    Aric
    Nor Cal
    2017 TRD pro
    Picking up a cap pretty soon and wanted to get some thoughts about where/how to pull cable for interior lights and third brake light. I was thinking about pulling straight from the battery, but someone mentioned using the seven way at the trailer.
    Any thoughts? is there a right/wrong way to do this?
    Thanks
  2. Nov 9, 2016 at 5:02 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    I ran a wire from the driver side taillight and up to the cab. There's a grommet under the drivers seat that you can go through and then run it to the fuse panel under the dash. I used a multimeter and found a circuit that was hot all the time and used a fuse tap to get power from it. I ground the third brake light and interior light with a bolt inside the taillight area (I sanded to bare metal for a good contact first). I also wired the brake light to the tail light for power, on mine I believe it was a green/red wire found at the back of the middle bulb.
  3. Nov 9, 2016 at 5:04 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    When I had mine installed, they pulled from the drivers side taillight.
    CusterFan likes this.
  4. Nov 9, 2016 at 5:47 PM
    ATR55
    Aric
    Nor Cal
    2017 TRD pro
    When I talked to the guys at the leer dealer they said the installed into the 7 way. Apparently leer makes a piece for this. Then he informed me that tying into the battery/tail light will void the factory warranty for all electrical on the vehicle. Does anyone know if this is accurate? if so I'm kind of confused as to how using the trailer power would be any different?
  5. Nov 9, 2016 at 5:51 PM
    Sig45
    Mark
    Maine
    Mine's a Leer and most around here are and all come from the same local dealer. All that I'm aware of are wired via the taillight.
    He uses those clip on splicers....then runs the wiring harness wires into those.
  6. Nov 9, 2016 at 8:29 PM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    For the 2nd gens there is not a hot wire anywhere on the rear of the vehicle, so if they tie into the trailer harness then you need the key on for power.
  7. Nov 8, 2017 at 10:47 PM
    navynuke
    navynuke Well-Known Member
    Lake Wylie, SC
    2014 TRD Off Road DC
    I pulled the brake light from the driver side and I already had run power straight from the battery so that's how I ran the power for the LED interior lights.
  8. Nov 10, 2017 at 6:01 PM
    Kelly6773
    Kelly6773 Well-Known Member
    Bob
    SC
    18 TRD sport DCLB
    For a third gen the leer dealer I talked to showed me a kit that piggy backs off the 7 flat round trailer plug. And you still use the plug for a trailer! But another dealer I talked to had not a clue what I was talking about. Not sure if they just didn’t want to mess with it or didn’t know anything!
