Electrical Question
Discussion in 'Technical Chat' started by YotaGangYotaGang, Apr 7, 2022.
  1. Apr 7, 2022 at 6:37 PM
    YotaGangYotaGang
    YotaGangYotaGang [OP] PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    What would be the name for a plug that has one male and two females for i can connect 2 inputs to charge my jackery? One by when my truck is turned on and one by solar. Thanks!
  2. Apr 7, 2022 at 8:21 PM
    YotaGangYotaGang
    Covina
  3. Apr 7, 2022 at 8:35 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I would call it a y plug. Not sure on what the connectors jackery used though in particular.
  4. Apr 7, 2022 at 8:56 PM
    toucan
    toucan Stupid truck
    Sam
    Oregon
    2013 DC offroad MGM. 2012 Super White SR 4x4 RC
    SCS/Bilstein/Icon/JBA/ Relentless/ATH/Smittybilt/Meso/Mobtown/Archive Garage/BAMF/Pioneer/Rockford Fosgate/Sundown/Wet Okole/Spiker Engineering/I'mMr.Yo/RAMMounts/Softopper/Weathertech/Factor55/Morel/DD
    I believe the input is 8mm. Might be tough to find a 8mm splitter thats all female, though.
  5. Apr 7, 2022 at 8:58 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
  6. Apr 7, 2022 at 9:00 PM
    toucan
    toucan Stupid truck
    Sam
    Oregon
  7. Apr 7, 2022 at 9:25 PM
    toucan
    toucan Stupid truck
    Sam
    Oregon
    My Jackery 1000 comes with an anderson plug to 2 female y adapter. The diagram on the box says you must use two solar panels simultaneously. I don't think you can use two separate charging sources. You would need to leave the solar panel unplugged till you turned off the vehicle.
  8. Apr 7, 2022 at 10:31 PM
    YotaGangYotaGang
    Covina
    my goal is to have both connected one off of my 12v while truck is on and the other connector for solar, I just want it to continue charging after i shut off the truck off of solar. idk if this will work or the jackery will brick. I’ll order off Amazon, worth a shot
  9. Apr 7, 2022 at 10:53 PM
    YotaGangYotaGang
    Covina
  10. Apr 8, 2022 at 1:12 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I’m going by what was posted above. Measure the jack diameter with Micrometer to be sure. Amazon has a really easy return process anyway.
