Electrical System upgrade GROUPBUY (BIG 3 PLUS)! **CLOSED**
Discussion in 'Closed Group Buys' started by ramonortiz55, Sep 14, 2015.
  1. Sep 25, 2015 at 4:28 AM
    #161
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Yes, you stick the wire in there and bolt down, clamping it, per se.
  2. Sep 25, 2015 at 5:33 AM
    #162
    ramonortiz55
    Ramon
    Texas
    stock
  3. Sep 25, 2015 at 6:39 AM
    #163
    BamaToy1997
    Bill
    Navarre, FL
    Before the cable is stuck in I used acid core solder to tin the end. This fills all cavities with solder and creates a stiff/rigid cable end. Once it is inserted then the set bolt is tightened down to secure it. I have had mine set up this way with dual batteries for around 2 years now. Even with heavy offroading and such I haven't had any electrical issues at all with my truck, the 1000 watt sub amp, or my winch.
    That being said, if you want the ends to have ring terminals on the end at the battery I can do that, adjusting the price of the kit for no digital terminals, but to be honest it's not a big difference in price.
    Ugly Betty likes this.
  4. Sep 25, 2015 at 8:56 AM
    #164
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I don't doubt they are solid connections I'm just looking to get military terminals for my purposes. I'm still thinking about what route I want to go for sure. I do dig the voltage readout.
    Out of curiosity why acid-core solder? Everything I've read recommends acid-free rosin core for electronics due to corrosion.
    techbill likes this.
  5. Sep 25, 2015 at 9:22 AM
    #165
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    Put me down for stage 4 with 200amp alternator, ring terminals and powder coat red.
    rka and BamaToy1997 like this.
  6. Sep 25, 2015 at 9:28 AM
    #166
    ramonortiz55
    Ramon
    Texas
    stock
    gotchu
  7. Sep 25, 2015 at 11:47 AM
    #167
    BamaToy1997
    Bill
    Navarre, FL
    I prefer acid core because it does etch the copper slightly for a better bond. I consider it the difference between painting over an existing paint job after cleaning (rosin core solder) versus sanding the body down a little first before painting (acid core)
    Ramon, I was thinking if it wasn't that difficult could you go back to your opening post with the name list and add next to their names an abbreviation of what they want to get. It will make things easier for me as we go so that I can have a general idea of materials. Some of the stuff I want to pre-order. If it is too much trouble let me know.
  8. Sep 25, 2015 at 12:08 PM
    #168
    BamaToy1997
    Bill
    Navarre, FL
    FYI, the builder got back with me and these are the powdercoat colors available:
    yellow, blue, red, black, white, lime green
  9. Sep 25, 2015 at 1:17 PM
    #169
    ramonortiz55
    Ramon
    Texas
    stock
    OP updated
  10. Sep 25, 2015 at 2:24 PM
    #170
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
    @BamaToy1997
    is the welding cable rated to withstand the chemicals is could come in contact with in an engine bay. oils, brake fluid, radiator fluid...
    its unlikely the cables would get soaked, but if i was working on my brakes and spilled some fluid would the cable possibly fail?
    BamaToy1997 likes this.
  11. Sep 25, 2015 at 2:38 PM
    #171
    BamaToy1997
    Bill
    Navarre, FL
    They are capable of withstanding the same as automotive grade cables. Same insulation type.
    "Excellent Impact and Abrasion Resistance Withstands Exposure to Oil, Acids, Alkalies, Heat, Moisture and Most Chemicals"
  12. Sep 25, 2015 at 2:58 PM
    #172
    4x4runner2002
    Zach
    2002 4x4 limited
    so i take its a neoprene type material and not epdm like standard welding wire?
    just making sure if i have an accident its not catastrophic
    BamaToy1997[QUOTED] likes this.
  13. Sep 25, 2015 at 3:25 PM
    #173
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    @ramonortiz55
    In this case I know I said stage 1, but I'm changing my mind to a stage 2 w/ 200A alt. For 1st gen.
  14. Sep 25, 2015 at 3:34 PM
    #174
    ramonortiz55
    Ramon
    Texas
    stock
    when its time to order, youll be able to finalize your specifics with the distributor..
    right now were compiling names..
  15. Sep 25, 2015 at 3:41 PM
    #175
    TashcomerTexas
    Ok just throwing that out there.
    ramonortiz55[OP] likes this.
  16. Sep 25, 2015 at 4:05 PM
    #176
    BamaToy1997
    Bill
    Navarre, FL
    As I recall EPDM coatings do all of the above protections.
  17. Sep 25, 2015 at 4:39 PM
    #177
    LiveFreeOrDie2015
    LiveFreeOrDie2015 Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    If your concerned with getting any fluids on the wire you can alway buy some split wire loom to protect the it. I thinks it's $5 for 10ft plus tape.
  18. Sep 25, 2015 at 8:52 PM
    #178
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Thanks
  19. Sep 26, 2015 at 7:11 PM
    #179
    ramonortiz55
    Ramon
    Texas
    stock
    To the top!
  20. Sep 26, 2015 at 7:20 PM
    #180
    ramonortiz55
    Ramon
    Texas
    stock
    The vendor/distributor does not have a design for V8 4runners..
    If anyone near Navarre, Florida has a V8 4runner, he is willing to make you a deal if you provide your truck as a guinea pig..
