Electrical Trouble
Discussion in '1st Gen. Tacomas (1995-2004)' started by lonzorizo, Dec 15, 2011.
  1. Dec 15, 2011 at 6:56 PM
    lonzorizo
    lonzorizo [OP] Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    So since I've had my taco (since march )the following have stopped working/been replaced: headlight went out, tail light went out, gauge went out twice, AC panel light went out, and license plate bulbs went out. I honestly don't know where to even start troubleshooting this problem. Anybody have any suggestions?
  2. Dec 15, 2011 at 8:12 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Headlights dim slightly on heavy bass/loud volumes b/c of new stereo system...will be doing the big three upgrade soon. But these problems arised far before my stereo install so can't be associated with that. And what grounds would I be checking? Never done any electrical work besides my stereo recently...I'm currently searching for info though.
  3. Dec 15, 2011 at 8:57 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    First off you need to pull your fuse on the stereo till you find the problem. Stereo should be the last thing on your mind when the problems like this popped up.
    Grounds on the truck are passenger side kick panel, some in the drivers side kick panel. One ground on your chassis short wire from ground to frame. Other one is on the back of the engine cylinder head to chassis. Any rust around those can be problem. One i believe in the dash cant remember where.
    If your blowing light bulbs like crazy you need to take a volt meter, pull the battery (disconnect) and do some ohms law across the truck to find your problem (grounds) . Check your fittings of your bulbs not rusted out or anything from making a good contact also.
  4. Dec 16, 2011 at 12:43 AM
    lonzorizo
    Lonnie
    Hoopa, Ca
    What do you mean do some ohms law across the truck? Like I said, not as knowledgeable as I'd like to be when it comes to this...hence why I'm asking for help. Thank you btw I appreciate it.
  5. Dec 16, 2011 at 1:24 AM
    lonzorizo
    Lonnie
    Hoopa, Ca
    More info that might help...the ac panel light would randomly come on, then turn back off...before finally completely going out. My instrument gauge bulb did the same thing, on and off throughout the day then nothing.
  6. Dec 16, 2011 at 8:29 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    He is assuming you know what a VOM is ( a Volt-Ohm Meter ).
    This is a hand-held device used to measure electric potential (voltage)
    and static electrical resistance (in Ohms).
    You can use it to determine if your alternator is putting out too
    much voltage ( should be no more that 15) and subsequently frying your electrical components.
    It can also be used to measure the resistance between your 'ground' connections and the frame (actual ground). Should be zero ohms.
    If you don't have a VOM, or know how to use one, then you need to go to a friend or relative who does.
    Hope this helps.
  7. Dec 16, 2011 at 11:12 AM
    lonzorizo
    Lonnie
    Hoopa, Ca
    OK yeah I've read up on that before and I have a multi meter too, thanks!
    Additionally, I've been thinking all damn night about this and I started thinking of other possible causes. Then I remember I just washed my truck a day before the gauge went out a couple days ago...kind of leads me into thinking something is getting wet? Is my hypothesis off base?
