Electricial help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Jun 7, 2024.
  1. Jun 7, 2024 at 8:23 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    2006 tacoma 2.7 4 cylinder
    Big 3
    Front battery agm.
    Rear battery agm
    Connected all with 1/0 ga wire power and ground.
    Truck Has 188k miles
    My question if my truck sits for 2 to 3 day and I go for turn it on and has a slow turn over is it bad and what causes ot how I fix it?
    The truck starts and voltage Will recharge 14.0
    Alt change 2 year ago
    Battery about 3 gotta check
    Is my starter going?
    Cause if I drive it and drive it the next day it will start up with no hesitation
    I'll drive it sat to Wed sit Thursday Fri then drive it again sat morning. That my routine
    HondaGM likes this.
  2. Jun 7, 2024 at 8:25 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I would check the batteries
    Check for a draw
    Check alternator output
    Dm93 and pinktaco808[OP] like this.
  3. Jun 7, 2024 at 8:27 PM
    pinktaco808
    What you mean check for a draw?
    HondaGM[QUOTED] likes this.
  4. Jun 7, 2024 at 8:31 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    A parasitic draw…
    Dm93 and pinktaco808[QUOTED][OP] like this.
  5. Jun 7, 2024 at 8:41 PM
    pinktaco808
    What that be though
  6. Jun 7, 2024 at 8:49 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    A parasitic draw is a type of electrical current drain that occurs in a vehicle when the ignition is turned off. It is called a parasitic draw because it continues to drain power from the vehicle's battery, even though the vehicle is not in use.
  7. Jun 7, 2024 at 8:49 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Meaning something in the the truck that is staying on/consuming power when the truck is off, there should be no more than a 50mA (0.05A) draw when the truck is off.
  8. Jun 7, 2024 at 9:35 PM
    pinktaco808
  9. Jun 7, 2024 at 9:35 PM
    pinktaco808
    What the best way to figure it out and fix it
  10. Jun 7, 2024 at 9:42 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    First need to determine if you have a drain, easiest no tools required way is to unhook the batteries, let it sit the length of time it is taking to drain them, then check them. If one or both are still dead then it's a battery issue, if not you have a drain killing them.
    The other way is with a clamp-on or in series ammeter to measure the actual current leaving the battery.
    https://youtu.be/bS6xak6Xmyo?si=QMCYmbu8dCamaOla
  11. Jun 7, 2024 at 10:27 PM
    pinktaco808
    Front battery 3 yrs old rear is 4 to 5 yrs
    HondaGM likes this.
  12. Jun 7, 2024 at 10:32 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So it very well could be a battery.
    Where I live (very hot climate) 2-3 years is about the average lifespan of an automotive battery, 4-5 years at most. In cooler climates they tend to last longer.
    HondaGM likes this.
  13. Jun 7, 2024 at 11:05 PM
    pinktaco808
    Live hawaii soo
    Well when have time this week, gonna change both out for a lead acid since I haven't had sounds for a while. What better napa or oreillys?
    HondaGM likes this.
  14. Jun 8, 2024 at 2:37 AM
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    Costco
    HondaGM likes this.
  15. Jun 8, 2024 at 11:23 AM
    pinktaco808
    Ok so please describe symptoms of these going bad
    Battery
    Alternator
    Starter
    Thanks
  16. Jun 8, 2024 at 11:34 AM
    pinktaco808
    Also had both on separate battery tender and soon as I took it off it drop to 70% for front and rear be 67%. Also tried reconditiong both battery
  17. Jun 8, 2024 at 12:49 PM
    pinktaco808
    How do you fix the parasitic draw?
  18. Jun 8, 2024 at 12:50 PM
    pinktaco808
    This was beginning of this year
  19. Jun 8, 2024 at 1:14 PM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    AGM battery needs higher voltage to charge properly or will shorten its life..try the GM diode to boost alternator voltage ...easy fix replace fuse with diode 5 min.fix check out. adventure 4x4. YT video ... I would start here first then ..proceed to parasitic drawl if needed.
    pinktaco808[OP] likes this.
  20. Jun 9, 2024 at 4:51 AM
    pinktaco808
    Might be alternator got new battery. Why when drive come complete stop at light it will drop to 12.8- 13.1 then go back to 14.3. If at stop it will also have a rough idle.
