Electrician
Discussion in 'Southern California' started by 87Tcyota, Aug 16, 2015.
  1. Aug 16, 2015 at 6:49 PM
    87Tcyota
    87Tcyota [OP] Paiza RIder
    Joel
    Whittier, Ca
    01 Lt taco
    Anybody do home electrical work that can help a fellow tacoma owner? Just moved in to a new place and my garage is all hooked up with outlets but no electricity works in there. Already Checked the electrical panel and nothing.
    Dj Suisav and opteron like this.
  2. Aug 16, 2015 at 9:46 PM
    Dj Suisav
    Dj Suisav Well-Known Member
    Saul
    San Antonio, TX
    2011 MGM DCSB Trd Sport
    RIP 2009 Super White DCSB Trd Sport
    I would help but I'm tx. Get a voltage tester and check the plugs and the breakers. Make sure there's power running to that breaker. Usually 120v
  3. Aug 16, 2015 at 9:57 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    This. You will find these in the bathrooms and possibly on an exterior wall
  4. Aug 16, 2015 at 9:58 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    That would suck
  5. Aug 17, 2015 at 8:24 AM
    Dj Suisav
    Saul
    San Antonio, TX
    Yea also check a GFCI!!
  6. Aug 17, 2015 at 9:02 AM
    OZ-T
    Peter North
    British Columbia
    Why would anybody wire a garage downstream from a GFCI ?
    Not saying it couldn't happen just makes zero sense
  7. Aug 17, 2015 at 9:11 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Because low T, obviously they don't have any man stuff that needs power.
  8. Aug 17, 2015 at 11:54 AM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    That's the way we have it setup as well.
    Any electrician here I tried my own wiring for a bathroom fan and failed.
    Subscribed to see if anyone here is available.
  9. Aug 17, 2015 at 11:56 AM
    Large
    Large Red
    The NEC (national electric code) changes rules like a baby changes diapers. Usually from a safety stand point, but there is always moisture in a garage rather than your house so a garage with electricity downstream from a GFCI is quite common. I'm sure there are similar practices in Canada.
  10. Aug 17, 2015 at 12:17 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Makes perfect sense. It will just trip out if too much load. I wish my garage was wired up this way with maybe one load off each gfci.
    Doing this way is just as safe with all outlets protected just like the gfci and is also cheaper bottom line.
    opteron likes this.
  11. Aug 17, 2015 at 1:54 PM
    OZ-T
    Peter North
    British Columbia
    Pretty certain you don't wire the inside of a garage on a gfi here , not any of the houses I've ever built , and what about compressor plugs or welding rig set ups or 20A workbench plugs ?
  12. Aug 17, 2015 at 1:55 PM
    OZ-T
    Peter North
    British Columbia
    Makes no sense , plug in a high start up draw machine like a tablesaw into one and see how that goes .
  13. Aug 17, 2015 at 2:02 PM
    opteron
    whittier, CA.
    2003 DB 4x4 SR5
    Sooooo .... any electrician that can help out in so cal?
  14. Aug 17, 2015 at 2:02 PM
    Large
    Large Red
    You are correct for the most part. A garage should have it's own circuit(s).
  15. Aug 17, 2015 at 2:04 PM
    OZ-T
    Peter North
    British Columbia
    Without a doubt
  16. Aug 17, 2015 at 2:05 PM
    Large
    Large Red
    Usually a builder thinks ahead and should assume the owner will want to power a drill, bandsaw, air mover, etc, something with a motor that draws a lot of amps and plans accordingly.
  17. Aug 17, 2015 at 2:22 PM
    OZ-T
    Peter North
    British Columbia
    I try
  18. Aug 17, 2015 at 2:40 PM
    jmaack
    Justin
    Helena Alabama
    Mine has 1 circuit.
    I wish mine did. I thought kitchens and garages were wired with 20 amp. I just went and checked and my kitchen and garage are 15. It was also built in 96
  19. Aug 17, 2015 at 2:41 PM
    jmaack
    Justin
    Helena Alabama
    I honestly wish my panel had another place for a 220 breaker. I'd love a heater in the winter. Fml
  20. Aug 17, 2015 at 3:00 PM
    ElderP
    ElderP Well-Known Member
    West Virginia
    15 Access 4x4 V6 SR5
    Installed Cooper At/3's (265/70R16) and ProComp 7089 Rims. Tinted front windows. Did the Fog Light Anytime mod. Did the tailgate mod. Added running boards. Adding sound Deadening from RAAMaudio. Replacing stock speakers with Polk Audio DB6501's.
    To save money, wire, a breaker and time. Often done by track house builders. I used to be an electrician and have seen that (and worse) many times. GFCI in a garage is cheap insurance (assuming no one ever vacs out their vehicles on a humid summer day in bare feet standing on concrete?) And yes, garages SHOULD have their own circuits.
